Gear Shifter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2008, 07:02 PM   #1 (permalink)
View tagpats's Photo Gallery
Gear Shifter
Has anyone experienced any squeaking or unusual noises when moving the gear shifter in their automatic transmission Camry? I have a 2007 SE V6 and recently noticed that when I sometimes shift from park to reverse and also into drive, there is a rubbing or a squeaking kind of noise.
The shift itself is not the issue, it's the lever that seems like it's causing some of the plastic to rub or flex or something. Not sure if this has always been the case and I never noticed it until now or if something is wearing in there.
tagpats is offline   Reply With Quote
Old 06-18-2008, 10:00 PM   #2 (permalink)
Camry Freak
98CamryLE's Avatar
View 98CamryLE's Photo Gallery
I'm not sure if it's related, but there is/was a TSB on a center console squeak a while ago. I think that squeak is more along the lines of a squeaking when the car goes over bumps, and requires that insulation is placed in the center tunnel/shifter housing.
I'm not sure if that TSB would help fix a squeak that happens when you are actually shifting from Park/Reverse/Drive.
2007 Camry Hybrid
98CamryLE is offline   Reply With Quote
Old 06-19-2008, 09:36 AM   #3 (permalink)
Thanks for the tip. I'll check it out.
Old 04-15-2011, 11:57 PM   #4 (permalink)
View deemaru's Photo Gallery
Any updates? i have a 2009 SE Camry and the shifter squeaks when I wiggle in D or shift between D - N....
deemaru is offline   Reply With Quote
Old 04-16-2011, 12:16 PM   #5 (permalink)
AML
Gameroom cash: $214800
View AML's Photo Gallery
It's normal. Theres no TSB for it that I can recall.
2011 Chrysler Town & Country Touring
2008 Toyota Camry Hybrid
2003 Yamaha V-Star 650 Classic
2002 Jaguar X-Type 2.5 AWD
AML is offline   Reply With Quote
