yes and yes.
it will take me a day or so to get them done and up where I can post.
I think there are more similarities than not all the way from early gen 5 through present.
its, to me, not as complex as it sounds, its just that the rear deck 'lid' is hemmed in by everything. once you move all the seat junk and undo the fasteners [pushpins.... but why they used two different types for the same purpose.... who knows. i plan to replace them all with new ones], move that black felty piece, then it just pops loose and slides out.
one thing that this made real clear to me is how little acoustic baffling material there is. your vibration would be easily remedied... in fact you may can pad it from the trunk. just put on some death metal or something and crawl in the trunk and start mashing on things.
I plan to get some carpet-pad material and put it everywhere I can, especially in the fore part of the rear wheel wells which have NO insulation at all.... cut down on the bad road noise that all toyotas and lexus's suffer from [i've had both]. GM does a much better job of this in the impala, saturn Aura, and newstyle malibus.... very very quiet
Originally Posted by TTM77
Zapp, could take some pictures of that back panel? good to see how it is apart.
Does yours remove like the Gen 6?
For mine, one of the rear speaker went bad (JBL speaker) and they said it would cost me about $700 if it weren't under warranty. Anyway, after that fix my back panel now vibrates when I hit bumps on the road. My warranty is out now but I wouldn't let them touch it again anyway. I tried to find the reason why it vibrate but couldn't see anything wrong. With your picture, I hope to track down where it might vibrate.
