Engine Problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-25-2008, 11:33 AM   #1 (permalink)
View Navi Bhandari's Photo Gallery
Gen5 Engine Problems
Is anybody else having this problem? I have a 2003 Toyota Camry LE with only 55,000 miles on it and my engine is starting to jump while its in park and while I am breaking at a stop light. Somebody said that it could be my RPM that needs to be readjusted but when I went to the dealership to ask them if that is possible they said that I would have to replace me computer chip which would cost a crap load . This is my first car that I bought so I don't want to be out and loose the money that I put into this car. If anyone knows how to fix this please let me know.
Thanks ahead of time.
Navi Bhandari is offline   Reply With Quote
Old 06-25-2008, 11:52 AM   #2 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
How high is the engine jumping? Does it have good hang time?
Seriously though, We need to know if its a 4 or 6 cylinder, Describe the problem better than saying "jumping" does it do it hot or cold? Do you maintain the car properly? etc...
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 06-25-2008, 11:56 AM   #3 (permalink)
View Stevemr2t's Photo Gallery
This could be a vacuum leak, AC unit kicking in etc.....
2009 SE Grey - Fully Loaded
TRD 18 Rims - Yoko SDrive Tires
TRD Air Filter
Custom Exhaust Tips
Smoked LED Taillights
Stevemr2t is offline   Reply With Quote
Old 06-25-2008, 12:53 PM   #4 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1077958
iTrader Score: 7 reviews
EGR Valve...if it's a V6
2002 Camry SE V6 "Snow White"
Old 06-25-2008, 01:10 PM   #5 (permalink)
Joined the dark side. :D
Gameroom cash: $656091
View workerant's Photo Gallery
Did U show the tech at dealer the problem or just talk with them verbally?
workerant is offline   Reply With Quote
Old 06-25-2008, 01:18 PM   #6 (permalink)
"Circle of trust"
View catric69's Photo Gallery
Read this first!
Need help with a rattle, noise, MIL, diagnosis, squeak, etc? Read this first.
catric69 is offline   Reply With Quote
Old 06-25-2008, 02:29 PM   #7 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
I've noticed this ever so slightly with my car - I'm waiting at a stop light and the RPMs go up just a tiny bit. If my foot is only on the brake lightly, the car will go about an inch forward. This only happens with the A/C on so I've come to the conclusion that it's the compressor cycling on and off. I have not noticed this in the other two Toyotas that I drive but they're also V6; mine is an I4. Guess the I4 doesn't have enough power to spare..ha ha!
That said, it's never been a real problem and seems to have all but gone away after my last oil and transmission fluid change in the last two months. Not sure how that could have an effect, I'm just stating what I've experienced.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 06-25-2008, 04:51 PM   #8 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Your description of the problem isn't very good. Engines can't "jump".
I'm guessing that you are simply getting a slight RPM surge at stops as the A/C compressor cycles on and off.
2006 Camry LE Special Edition
Old 06-25-2008, 05:50 PM   #9 (permalink)
Yeah, it's probably just the engine idling up when the compressor kicks in. An annoyance maybe but nothing to be concerned about.
moving forward
Old 06-25-2008, 05:53 PM   #10 (permalink)
View marc780's Photo Gallery
Your description is vague but if your engine "jump" is minor its probably normal like they are all saying. Especially if the idle jumps then quickly returns to normal. If it is not minor, and what you are saying is that you can feel too much engine movement OR rough idle, try to narrow down the problem. An engine in perfect shape with good idle will still jump if an engine mount is broken. So have your engine mounts checked.
If its rough engine idle then thats another seperate problem. Like the one the other people are talking about above. You could have either or both problems so i'd find out what partss involved before throwing money at it.
Old 06-25-2008, 06:04 PM   #11 (permalink)
To the OP - how much are your RPMs going up by? Mine only rev up maybe 150 RPMs max when the compressor kicks in. Most times I can't feel it at all. If it's more than that, perhaps someone else can chime in with what that could be..
moving forward
Old 06-25-2008, 06:09 PM   #12 (permalink)
The Connoisseur
CharmCityES's Avatar
my car does this as well....2003 SE 4cyl
its just the a/c compressor cycling on and off, because mine only has this issue when the a/c is on
The "Executive Sedan"
Old 06-25-2008, 08:08 PM   #13 (permalink)
Or an easy fix is to turn off the AC. If you want to see that jump is cause by the AC than turn it back on and the "jump" should start almost right away.
If you give the dealer enough trouble I'm sure some guy will just remove the AC and say "Problem solved"
Old 06-25-2008, 10:39 PM   #14 (permalink)
sorry if i was not clear on my problem. basically when i start my car up, yes my rpm will start jumping when i am not pressing the gas and while i am at a red light or stop sign. as well, i noticed to day, that when i am driving and if i have my ac turned on and i am at a red light for a while my car will just cut off on me and i have to restart my car and turn off the ac. someone told me that it could be my idle air control that might need to be replaced. but i am not sure what to do. i am going to take it to the dealership tomorrow and see if they can take a look at it and tell me what is going on with it. if anyone else can help please do.
Old 06-26-2008, 10:20 AM   #15 (permalink)
I'd try cleaning it myself first before emptying my ban kaccount at the dealership. But if you do it'll cost you ($3.00 for a can of cleaner.). Nothing to lose.
How to: Cleaning Throttle Body, Pictorial
