Can't balance wheels on 2007 Camry? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-26-2008, 03:34 PM   #1 (permalink)
2007 Titanium Camry SE V6
View costanza's Photo Gallery
I replaced the stock 17" wheels (17"x7", +45 offset, 5-114.3) that came on my '07 Camry SE with a set of 17" Lexus GS "take-off" wheels (made by Toyota)from lexus-parts.com (17 x 7.5 inches, 5-114.3, et- 35 mm, 27.35 lbs). I re-used the Toyo Proxes 215/55/17 tires. The independent shop that normally balances these same wheels on my '06 Lexus GS300 with NO PROBLEM says he can't balance these wheels! He's tried 3 times and they still cause the steering wheel of my Camry to shimmy between 70-80 mph. I didn't actually speak to him, but my wife said he told her they needed a "static" balance. They did swap the TPM's from my stock wheels to these wheels, but my GS300's wheels have these as well, although maybe a different model. Any idea what I need to ask a tire shop in order to find out if they have what it takes to balance these wheels/tires?
THANKS!
costanza is offline   Reply With Quote
Old 06-26-2008, 03:39 PM   #2 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
Find out if they only do Dynamic balance, or if they have a balancer capable of Static balancing
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 06-26-2008, 04:15 PM   #3 (permalink)
View eddiecruz's Photo Gallery
I have the same vibration issue on my Camry with stock proxies. Please let me know what you did to fix the vibration issue.
eddiecruz is offline   Reply With Quote
Old 06-26-2008, 05:23 PM   #4 (permalink)
View toyomoho's Photo Gallery
Are you sure it is the tires/rims and not the bearings, hubs, etc?
Old 06-26-2008, 05:25 PM   #5 (permalink)
JSM1284's Avatar
Good point. Are you using Hub Centric rings?
2005 Lexus ES330
Old 06-26-2008, 05:42 PM   #6 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Shouldn't need rings with those Lexus wheels...
Old 06-26-2008, 05:45 PM   #7 (permalink)
JSM1284's Avatar
Ah, Didn't know if they had the same hub bore or not.
2005 Lexus ES330
Old 06-26-2008, 06:24 PM   #8 (permalink)
Blue Ribbon FTW!
fdexclpl's Avatar
View fdexclpl's Photo Gallery
If you had the issue from the beginning check out T-SB 0106-08 "Steering Wheel Flutter/Body Vibration" It involves replacing both front hubs.
'07 Camry LE V6 - Blue Ribbon Metallic - 6-disc JBL - Moonroof
Someday I will list my mods here
Originally Posted by TRD VVTi View Post
I am a hater in one regard, I hate stupid.
fdexclpl is offline   Reply With Quote
Old 06-26-2008, 07:12 PM   #9 (permalink)
The Connoisseur
CharmCityES's Avatar
agreed with above postings...make sure to check TSB 0106-08 on the hubs....also, make sure the shop is doing both a static and dynamic balence to relieve both shimmy and wheel tramp....most newer balencers have a road force balence setting that simulates the pressure of the vehice on the road to give accurate balence readings, and a smartweight setting to balence the wheels with minimum weight....id take it to the dealer and make sure the wheels are balenced properly, the runout on the hubs is correct, and the wheels are torqued to spec with the correct star pattern torquing process....there are alot of small things that have a huge effect on wheel balence...another issue sometimes is that the tire isnt phase matched with the wheel, which creates a heavily unbalenced wheel/tire which requires too much wheel weight to balence properly....personally, id take it to your toyota dealer to make sure the TSB isnt the root cause, and then go from there
good luck!
-Corey
The "Executive Sedan"
Old 06-26-2008, 08:07 PM   #10 (permalink)
Thanks! I didn't have the problem until I switched wheels. I can't find the info on that TSB though
Old 06-26-2008, 08:31 PM   #11 (permalink)
low-n-slow
View GHSER7's Photo Gallery
do you have the 10 spoke wheels? If so, do you have any pics? I 'vs got someone local selling some and wanted to know how it looked on the car already.....thanks!
GHSER7 is offline   Reply With Quote
Old 06-27-2008, 12:25 PM   #12 (permalink)
Stewiefied Racing CEO
leinadneon's Avatar
View leinadneon's Photo Gallery
hey let me know what happens I'm having the same issue
leinadneon is offline   Reply With Quote
Old 06-30-2008, 01:52 PM   #13 (permalink)
Rapid Roy's Avatar
View Rapid Roy's Photo Gallery
THANKS!
I had a shimmy at 60 to 65mph with my 20's when I first got my car. They were a dealer installed option so the fixed it under waranty. Here's what they did. 1st they used 4 different hunter road force balancing machines and balanced my wheels 6 times. Still had some shimmy. The finally installed these new type of weights and they solved the problems.
They were brand new at the time. Now it looks like they are using them all the time. Toyota are knows to be finicky with aftermarket wheels. Maybe you shop can get these in.
Rapid Roy is offline   Reply With Quote
