update
Update:
engine: 4 cyl.
91,000 miles
Here are the things that I think stand out that I have record of that have been done to the vehicle. I know it isn't much. Or that detailed of records.
03/2004 - alignment, front brake rotors resurfaced/turned.
10/2004- steering/suspension checked
10/2005- steering/suspension checked
12/2005- manufacturer rec. maint. done., 4 wheel alignment, transmission fluid flushed, air filter replaced, tires rotated, battery replaced, front brake rotors resurfaced.
Also, 2 times I have noticed when stopped at a stop light with my foot firmly on the brake, the pedal sinks in a couple inches after a minute or two. Does this mean air in lines, worn out brakes, master cylinder malfunction. I will use the search function. I can probably read up on this in the car a manual, but if any of you have any suggestions thanks.
