Little air from vents, fan blowing great - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2008, 01:08 PM   #1 (permalink)
View dansk's Photo Gallery
Newbie here. I have a 2002 camry and I don't get very much air coming out of the vents when A/C is on. Air is cold but no volume. Blower motor is kicking butt. I have the manual and figured it could be the Mode Damper Servo or just some ducts coming off. Do I need to take the whole dash out to get to the Mode Damp Servo or is there an easier way?
Thanks, Dann
dansk is offline   Reply With Quote
Old 06-29-2008, 02:14 PM   #2 (permalink)
View canddmeyer's Photo Gallery
The air should be coming out of somewhere, whether it be the defroster, midlevel, or floor vents. If you find it coming out of somewhere other than what it is set for, then you are correct to assume something under the dash is broken and needs to be serviced.
Using the recirculation mode also increases the cabin airflow. You may also have a clogged cabin filter, if your vehicle is so equipped. I doubt the ducting is the problem.
canddmeyer is online now   Reply With Quote
Old 06-29-2008, 02:14 PM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Have you checked the filter?
2007 Camry 2.4L 5M
Old 06-29-2008, 02:43 PM   #4 (permalink)
After reading from the archive, that was the problem. Cabin air filter. Now I have air again. Gonna be over 100 degrees today. Thanks for all the help, you guys nailed it! Funny thing is that the diagnotics in the service manual dosen't mention the cabin air filter.
Dann
Old 06-30-2008, 12:36 PM   #5 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Gen5
Dann
They probably figure if you're smart enough to use the repair manual, you'd be smart enough to change the cabin air filter when required. It's in the maintenance manual, after all.
2006 Camry LE Special Edition
Old 06-30-2008, 09:12 PM   #6 (permalink)
Thanks, I just read the diagnostic part and it didn't mention anything at all about the filter. Oh well, all is good. Great to be on this site. I try to figure stuff out first and then go here to get the short cuts, but this was an easy fix. Just didn't spell it out in the manual where I was looking.
Thanks, Dann
