Oil change V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-01-2008, 02:27 AM   #1 (permalink)
View JDM112's Photo Gallery
Oil change V6
I decided to try to do my first oil change. Its a 2008 camry se v6, with about 4000 miles on it. Followed all the steps outlined in that pdf file for the avalon oil change and even watched the youtube video for the oil change on the camry v6. Everything went well except that i could not get the filter housing out. I think it was overtorqued at the factory. I even used a filter wrench, bought at autozone, but could not get it out, i turned it counterclockwise, but to no avail. Therefore, i just drained the old oil and put in new motor oil. Will this have any effect on the engine? being that i did not change the filter element??? Just a curiosity, any comments would be appreciated
JDM112 is offline   Reply With Quote
Old 07-01-2008, 06:10 AM   #2 (permalink)
Joined the dark side. :D
Gameroom cash: $654791
View workerant's Photo Gallery
hahaha.. yes it is very hard to get it out the first time.. as some1 stated that they hired Robot Cop to put on these oil filter's cap.
I believe it is recommended to change oil filter every oil change but OK to change it consecutively. I wonder if we can tell how "bad" the oil is that came out of the car. Any oil change expert here can answer?
workerant is online now   Reply With Quote
Old 07-01-2008, 07:35 AM   #3 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
The oil coming out at 4k miles should be pretty clean and if you pull and study the filter you should find any small metal frags that got caught up after the first few miles and break in and wear. Mine had a minimal amount that I could see. Take it to the dealer next time and let them change the oil. In the mean time, save the receipt for the oil. Document the mileage on the receipt. Get the correct size wrench and try using it to replace the filter, again. There are discussions here about 'the wrench'.
gdanaher is offline   Reply With Quote
Old 07-01-2008, 11:05 AM   #4 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
You should change the filter also.
2006 Camry LE Special Edition
Old 07-01-2008, 11:13 AM   #5 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
Some believe it is actually more crucial to change the filter rather than the oil itself....
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 07-01-2008, 12:30 PM   #6 (permalink)
2007 Camry SE V6
Gameroom cash: $132790
View thrawnis's Photo Gallery
The first oil/filter change, in my opinion, is the most important. The first few thousand miles are probably the most likely to introduce metal shavings into the oil. Since the oil filter will catch any sizable metal shavings, I would not be very concerned about the fact that you did not change the filter this time around. However, it is very important to remember that a filter that has caught a significant amount of contaminants and shavings will not flow as freely as oil flowing through a brand new filter. My assumption is that there should not be enough garbage in your filter right now that the oil flow or protection is significantly affected. Just make sure that you change the filter the next time around.
In the future, I would recommend changing the oil filter with every oil change. The small amount of money you would spend on a new filter each time can give you good piece of mind when it comes to protecting your engine!
My Update Thread: http://www.toyotanation.com/forum/sh...d.php?t=319520
2007 Camry V6 SE | Blue Ribbon Metallic | UR Strut/Sway Bar | K&N SRI | Magnaflow mufflers | H&R Springs | TSW Cadwell 19x8 Wheels | 6000k HIDs | Reus Custom Sound System | Tinted Headlights | Smoked LED Taillights | More
thrawnis is offline   Reply With Quote
Old 07-01-2008, 01:29 PM   #7 (permalink)
Blue Ribbon FTW!
fdexclpl's Avatar
View fdexclpl's Photo Gallery
Pick up this filter housing tool...
http://www.toolsource.com/toyota-fil...-p-100298.html
It will make the job much easier.
'07 Camry LE V6 - Blue Ribbon Metallic - 6-disc JBL - Moonroof
Someday I will list my mods here
Originally Posted by TRD VVTi View Post
I am a hater in one regard, I hate stupid.
fdexclpl is offline   Reply With Quote
