you will have to remove the upper trim for the entire middle console. starting from the armrest, open up the top compartment and you will see thats where the upper trim starts. using a taped up screwdriver or equivalent, start prying the trim out from there... once you get it started, you can probably do the rest by hand. the upper trim consists of the cupholder, and surrounds the shifter and the e-brake. you should be able to get the cigarette lighter out then.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
