My wife calls me at work today, stating her CEL came on. This is a 2002 Camry SE with 74K miles. Just took the car to Autozone and the codes are p0440, p0441 & p0446. I kind of looked around on here and did not see anyone with all three of those codes. Could have missed it though. I have already tightened the fuel cap, but have not disconnected the battery. Could this just be a VSV problem? Or is there anyway to narrow this down a bit farther? Any help would be greatly appreciated.
Thank you,
Jason
94' Camry XLE, Tan Leather, 1mz-fe, 173,000 miles
02' Camry SE, Black Leather, V6, 92,000 miles Peak Performance
Check Engine Light, Malfunction Indicator Lamp, Same difference.
__________________ Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals “My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
Actually, I already knew. That's why I stated what I did. Now maybe, you'll learn something besides trolling after me today...
01–36
INTRODUCTION
– TERMS
Author: Date:
36
2002 CAMRY REPAIR MANUAL (RM881U)
TERMS
ABBREVIATIONS USED IN THIS MANUAL
Abbreviations Meaning
ABS Anti–Lock Brake System
A/C Air Conditioner
AC Alternating Current
ACC Accessory
ACIS Acoustic Control Induction System
ACSD Automatic Cold Start Device
A.D.D. Automatic Disconnecting Differential
A/F Air–Fuel Ratio
AHC Active Height Control Suspension
ALR Automatic Locking Retractor
ALT Alternator
AMP Amplifier
ANT Antenna
APPROX. Approximately
ASSY Assembly
A/T, ATM Automatic Transmission (Transaxle)
ATF Automatic Transmission Fluid
AUTO Automatic
AUX Auxiliary
AVG Average
AVS Adaptive Variable Suspension
B+ Battery Voltage
BA Brake Assist
BACS Boost Altitude Compensation System
BAT Battery
BDC Bottom Dead Center
B/L Bi–Level
B/S Bore–Stroke Ratio
BTDC Before Top Dead Center
BVSV Bimetallic Vacuum Switching Valve
Calif. California
CB Circuit Breaker
CCo Catalytic Converter For Oxidation
CD Compact Disc
CF Cornering Force
CG Center Of Gravity
CH Channel
CKD Complete Knock Down
COMB. Combination
CPE Coupe
CPS Combustion Pressure Sensor
CPU Central Processing Unit
CRS Child Restraint System
CTR Center
C/V Check Valve
CV Control Valve
CW Curb Weight
DC Direct Current
INTRODUCTION
– TERMS
01–37
Author: Date:
37
DEF Defogger
DFL Deflector
DIFF. Differential
DIFF. LOCK Differential Lock
D/INJ Direct Injection
DLC Data Link Connector
DLI Distributorless Ignition
DOHC Double Overhead Cam shaft
DP Dash Pot
DS Dead Soak
DSP Digital Signal Processor
DTC Diagnostic Trouble Code
DVD Digital Versatible Disc
EBD Electric Brake Force Distribution
ECAM Engine Control And Measurement System
ECD Electronic Controlled Diesel
ECDY Eddy Current Dynamometer
ECT Electronic Control Transmission
ECU Electronic Control Unit
ED Electro–Deposited Coating
EDU Electronic Driving Unit
EDIC Electric Diesel Injection Control
EFI Electronic Fuel Injection
E/G Engine
EGR Exhaust Gas Recirculation
EGR–VM EGR–Vacuum Modulator
ELR Emergency Locking Retractor
EMPS Electric Motor Power Steering
ENG Engine
ESA Electronic Spark Advance
ETCS–i Electronic Throttle Control System–intelligent
EVAP Evaporative Emission Control
EVP Evaporator
E–VRV Electric Vacuum Regulating Valve
EX Exhaust
FE Fuel Economy
FF Front–Engine Front–Wheel–Drive
F/G Fuel Gauge
FIPG Formed In Place Gasket
FL Fusible Link
F/P Fuel Pump
FPU Fuel Pressure Up
Fr Front
FR Front–Engine Rear–Wheel–Drive
F/W Flywheel
FW/D Flywheel Damper
FWD Front–Wheel–Drive
GAS Gasoline
GND Ground
GPS Global Positioning System
HAC High Altitude Compensator
01–38
INTRODUCTION
– TERMS
Author: Date:
38
H/B Hatchback
H–FUSE High Current Fuse
HI High
HID High Intensity Discharge (Head Lamp)
HSG Housing
HT Hard Top
HWS Heated Windshield System
IC Integrated Circuit
IDI Indirect Diesel Injection
IFS Independent Front Suspension
IG Ignition
IIA Integrated Ignition Assembly
IN Intake (Manifold, Valve)
INT Intermittent
I/P Instrument Panel
IRS Independent Rear Suspension
ISC Idle Speed Control
J/B Junction Block
J/C Junction Connector
KD Kick–Down
LAN Local Area Network
LB Liftback
LCD Liquid Crystal Display
LED Light Emitting Diode
LH Left–Hand
LHD Left–Hand Drive
L/H/W Length, Height, Width
LLC Long–Life Coolant
LNG Liquified Natural Gas
LO Low
LPG Liquified Petroleum Gas
LSD Limited Slip Differential
LSP & PV Load Sensing Proportioning And Bypass Valve
LSPV Load Sensing Proportioning Valve
MAP Manifold Absolute Pressure
MAX. Maximum
MIC Microphone
MIL Malfunction Indicator Lamp
MIN. Minimum
MG1 Motor Generator No.1
MG2 Motor Generator No.2
MP Multipurpose
MPI Multipoint Electronic Injection
MPX Multiplex Communication System
M/T, MTM Manual Transmission (Transaxle)
MT Mount
MTG Mounting
N Neutral
NA Natural Aspiration
NO. Number
O2S Oxygen Sensor
INTRODUCTION
– TERMS
01–39
Author: Date:
39
O/D Overdrive
OEM Original Equipment Manufacturing
OHC Overhead Camshaft
OHV Overhead Valve
OPT Option
ORVR On–board Refilling Vapor Recovery
O/S Oversize
P & BV Proportioning And Bypass Valve
PCS Power Control System
PCV Positive Crankcase Ventilation
PKB Parking Brake
PPS Progressive Power Steering
PS Power Steering
PTO Power Take–Off
P/W Power Window
R & P Rack And Pinion
RAM Random Access Memory
R/B Relay Block
RBS Recirculating Ball Type Steering
R/F Reinforcement
RFS Rigid Front Suspension
RH Right–Hand
RHD Right–Hand Drive
RLY Relay
ROM Read Only Memory
Rr Rear
RR Rear–Engine Rear–Wheel–Drive
RRS Rigid Rear Suspension
RWD Rear–Wheel–Drive
SDN Sedan
SEN Sensor
SICS Starting Injection Control System
SOC State Of Charge
SOHC Single Overhead Camshaft
SPEC Specification
SPI Single Point Injection
SRS Supplemental Restraint System
SSM Special Service Materials
SST Special Service Tools
STD Standard
STJ Cold–Start Fuel Injection
SW Switch
SYS System
T/A Transaxle
TACH Tachometer
TBI Throttle Body Electronic Fuel Injection
TC Turbocharger
TCCS TOYOTA Computer–Controlled System
TCV Timing Control Valve
TDC Top Dead Center
TEMP. Temperature
01–40
INTRODUCTION
– TERMS
Author: Date:
40
TEMS TOYOTA Electronic Modulated Suspension
TFT Toyota Free–Tronic
TIS Total Information System For Vehicle Development
T/M Transmission
TMC TOYOTA Motor Corporation
TMMK TOYOTA Motor Manufacturing Kentucky, Inc.
TRAC Traction Control System
TURBO Turbocharge
TWC Three–Way Catalyst
U/D Underdrive
U/S Undersize
VCV Vacuum Control Valve
VENT Ventilator
VIN Vehicle Identification Number
VPS Variable Power Steering
VSC Vehicle Stability Control
VSV Vacuum Switching Valve
VTV Vacuum Transmitting Valve
VVT–i Variable Valve Timing–intelligent
W/ With
WGN Wagon
W/H Wire Harness
W/O Without
WU–TWC Warm Up Three–way Catalytic Converter
WU–OC Warm Up Oxidation Catalytic Converter
1ST First
2ND Second
2WD Two Wheel Drive Vehicle (4 x 2)
3RD Third
4TH Fourth
4WD Four Wheel Drive Vehicle (4 x 4)
4WS Four Wheel Steering System
5TH Fifth
01048–02
INTRODUCTION
– TERMS
01–41
Author: Date:
41
GLOSSARY OF SAE AND TOYOTA TERMS
This glossary lists all SAE–J1930 terms and abbreviations used in this manual in compliance with SAE recommendations,
as well as their TOYOTA equivalents.
SAE
ABBREVIATIONS
SAE TERMS
TOYOTA TERMS
( )––ABBREVIATIONS
A/C Air Conditioning Air Conditioner
ACL Air Cleaner Air Cleaner, A/CL
AIR Secondary Air Injection Air Injection (AI)
AP Accelerator Pedal –
B+ Battery Positive Voltage +B, Battery Voltage
BARO Barometric Pressure HAC
CAC Charge Air Cooler Intercooler
CARB Carburetor Carburetor
CFI Continuous Fuel Injection –
CKP Crankshaft Position Crank Angle
CL Closed Loop Closed Loop
CMP Camshaft Position Cam Angle
CPP Clutch Pedal Position –
CTOX Continuous Trap Oxidizer –
CTP Closed Throttle Position LL ON, Idle ON
DFI Direct Fuel Injection (Diesel) Direct Injection (DI)
DI Distributor Ignition –
DLC1
DLC2
DLC3
Data Link Connector 1
Data Link Connector 2
Data Link Connector 3
1: Check Connector
2: Total Diagnosis Communication Link (TDCL)
3: OBD II Diagnostic Connector
DTC Diagnostic Trouble Code Diagnostic Trouble Code
DTM Diagnostic Test Mode –
ECL Engine Control Level –
ECM Engine Control Module Engine ECU (Electronic Control Unit)
ECT Engine Coolant Temperature Coolant Temperature, Water Temperature (THW)
EEPROM Electrically Erasable Programmable Read Only Memory
(EEPROM),
Erasable Programmable Read Only Memory (EPROM)
EFE Early Fuel Evaporation Cold Mixture Heater (CMH), Heat Control Valve (HCV)
EGR Exhaust Gas Recirculation Exhaust Gas Recirculation (EGR)
EI Electronic Ignition TOYOTA Distributorless Ignition (TDI)
EM Engine Modification Engine Modification (EM)
EPROM Erasable Programmable Read Only Memory Programmable Read Only Memory (PROM)
EVAP Evaporative Emission Evaporative Emission Control (EVAP)
FC Fan Control –
FEEPROM
Flash Electrically Erasable Programmable
Read Only Memory
FEPROM Flash Erasable Programmable Read Only Memory –
FF Flexible Fuel –
FP Fuel Pump Fuel Pump
GEN Generator Alternator
GND Ground Ground (GND)
2S)
IAC Idle Air Control Idle Speed Control (ISC)
IAT Intake Air Temperature Intake or Inlet Air Temperature
ICM Ignition Control Module –
IFI Indirect Fuel Injection Indirect Injection (IDL)
IFS Inertia Fuel–Shutoff –
ISC Idle Speed Control –
KS Knock Sensor Knock Sensor
MAF Mass Air Flow Air Flow Meter
MAP Manifold Absolute Pressure Manifold Pressure Intake Vacuum
MC Mixture Control
Electric Bleed Air Control Valve (EBCV)
Mixture Control Valve (MCV)
Electric Air Control Valve (EACV)
MDP Manifold Differential Pressure –
MFI Multiport Fuel Injection Electronic Fuel Injection (EFI)
MIL Malfunction Indicator Lamp Check Engine Lamp
MST Manifold Surface Temperature –
MVZ Manifold Vacuum Zone –
NVRAM Non–Volatile Random Access Memory –
O2S Oxygen Sensor Oxygen Sensor, O2 Sensor (O2S)
OBD On–Board Diagnostic On–Board Diagnostic System (OBD)
OC Oxidation Catalytic Converter Oxidation Catalyst Convert (OC), CCo
OP Open Loop Open Loop
PAIR Pulsed Secondary Air Injection Air Suction (AS)
PCM Powertrain Control Module –
PNP Park/Neutral Position –
PROM Programmable Read Only Memory –
PSP Power Steering Pressure –
PTOX Periodic Trap Oxidizer
Diesel Particulate Filter (DPF)
Diesel Particulate Trap (DPT)
RAM Random Access Memory Random Access Memory (RAM)
RM Relay Module –
ROM Read Only Memory Read Only Memory (ROM)
RPM Engine Speed Engine Speed
SC Supercharger Supercharger
SCB Supercharger Bypass E–ABV
SFI Sequential Multiport Fuel Injection Electronic Fuel Injection (EFI), Sequential Injection
SPL Smoke Puff Limiter –
SRI Service Reminder Indicator –
SRT System Readiness Test –
ST Scan Tool –
TB Throttle Body Throttle Body
TBI Throttle Body Fuel Injection
Central Fuel Injection (Ci)
TC Turbocharger Turbocharger
TCC Torque Converter Clutch Torque Converter
INTRODUCTION
– TERMS
01–43
Author: Date:
43
TCM Transmission Control Module Transmission ECU, ECT ECU
TP Throttle Position Throttle Position
TR Transmission Range –
TVV Thermal Vacuum Valve
Bimetallic Vacuum Switching Valve (BVSV)
Thermostatic Vacuum Switching Valve (TVSV)
TWC Three–Way Catalytic Converter
Three–Way Catalytic (TWC)
Manifold Converter
CC
RO
TWC+OC Three–Way + Oxidation Catalytic Converter CC
R + CCo
VAF Volume Air Flow Air Flow Meter
VR Voltage Regulator Voltage Regulator
VSS Vehicle Speed Sensor Vehicle Speed Sensor
WOT Wide Open Throttle Full Throttle
WU–OC Warm Up Oxidation Catalytic Converter –
WU–TWC Warm Up Three–Way Catalytic Converter –
3GR Third Gear –
