Aftermarket vs OEM wheels - weights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-07-2008, 01:23 AM   #1 (permalink)
fredberg's Avatar
View fredberg's Photo Gallery
Gen5 Aftermarket vs OEM wheels - weights
i've always wondered. do aftermarket wheels weigh LESS than OEM steel wheels of the same size? i figure the aftermarkets use a lighter alloy, thus being a little lighter all around. jus curious...
fredberg is offline   Reply With Quote
Old 07-07-2008, 09:06 AM   #2 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
Here is an answer in general.
- Brandname/Expensive wheels weight less than OEM wheels.
- OEM wheels weight less than most cheap aftermarket wheels (especially made in China/Korea)
Old 07-07-2008, 10:11 AM   #3 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
most aftermarket wheels are heavier than OEM steel rims or alloys ... unfortunately, because the market is flooded with bulky replicas and bargain wheels
the difference is this:
say that the aftermarket wheel is +3" larger in diameter and +2" larger in width ... that means you can run a stiffer sidewall (40-series instead of 70-series) and a wider tire, meaning better handling and extra grip if you choose your products right
plus you have the added benefit of aesthetics...
like lammdi said, if you are able to dish out some extra money - aftermarket wheels can be had for lighter than stock ... as little as 8 lbs per wheel sometimes (as opposed to the OEM 18+ lbs per wheel)
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 07-07-2008, 10:21 AM   #4 (permalink)
on full afterburner
Gameroom cash: $1340897
Yes, in most cases, assuming you stick with a reputable brand.
I'd recommend anything from Rays, Work, SSR, Advan, BBS, Enkei, WedsSport.
Old 08-07-2008, 05:53 PM   #5 (permalink)
fredberg's Avatar
Gen5 lighter!
I just swapped the OEM 15 steelies with 15's from MB Wheels ("Seven X"), using the same tires. I found that the tire + aftermarket wheel is 4-5 lbs lighter than the OEM combination.
What does this mean in terms of acceleration, braking, or at the least, workload of the engine?
