How do I clear the check engine light? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-11-2008, 09:38 PM   #1 (permalink)
SMR
View SMR's Photo Gallery
Gen5 How do I clear the check engine light?
I have a 2003 Camry 4 cylinder and I added Sea Foam into the line that goes from the brake booster and now the check engine light is on.
Car is running great now.
Do I need an OBDII to clear the code (visit Autozone) or disconnecting the battery will do the trick ?
SMR is offline   Reply With Quote
Old 07-11-2008, 09:51 PM   #2 (permalink)
Forgive meee.
liquidi3ladz's Avatar
View liquidi3ladz's Photo Gallery
You can disconnect the negative terminal. But since you seafoamed your car and got the MIL it will clear itself in a few days.
2002 Camry LE I4
liquidi3ladz is offline   Reply With Quote
Old 07-11-2008, 10:25 PM   #3 (permalink)
SMR
ok, thanks for the info...btw what does MIL stand for ?
Old 07-11-2008, 10:39 PM   #4 (permalink)
I Eat Accords! W_(^_^)_W
my.rims.are.stock's Avatar
Gameroom cash: $114800
View my.rims.are.stock's Photo Gallery
USA
SMR,
Malfunction Indicator Light
-Matt
my.rims.are.stock is offline   Reply With Quote
Old 07-12-2008, 10:49 AM   #5 (permalink)
Gameroom cash: $303755
If I were you I would visit Autozone and have them read and clear the code. Write down the code. This way you will know what the code was for future reference. If you choose to just disconnect the battey, write down all your radio preset channels. They will be erased too and you will have to re-enter them after the battery is reconnected.
Mike
Old 07-12-2008, 01:21 PM   #6 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Gen5
Mike
You just need to disconnect the negative battery cable. By doing so, you will clear the code and not have to reset the radio stations.
MIL is the correct term for the check engine light.
Is the search function broken?
2006 Camry LE Special Edition
Old 07-16-2008, 01:50 PM   #7 (permalink)
Banned
View TRD_EarBanger's Photo Gallery
it is on mine , DAMNIT ALL
TRD_EarBanger is offline   Reply With Quote
Old 07-16-2008, 02:34 PM   #8 (permalink)
Joined the dark side. :D
Gameroom cash: $654791
View workerant's Photo Gallery
You don't lose Ur preset radio stations when disconnect the battery?
workerant is online now   Reply With Quote
Old 07-16-2008, 04:06 PM   #9 (permalink)
Crash Test Dummy
View white07cam's Photo Gallery
i seem to lose all my radio presets whenever i let any member of my country music loving family drive my car........
2007 Super White CE 5-spd. Stock 4 Lyfe, well I have new driver side doors and side pillar.. are those mods?
As of March 1, another $2200 body shop bill due to deer attack..
white07cam is offline   Reply With Quote
Old 07-16-2008, 04:14 PM   #10 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $462074
View BlackCamSe's Photo Gallery
Gen6
Not true. You will still lose your presets, and colck will be reset also.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 07-22-2008, 11:13 PM   #11 (permalink)
SMR
USA
The MILs automatically got cleared out on both of my Camrys...I got a 95 and a 03 model. Thanks for the input.
Old 07-23-2008, 11:00 AM   #12 (permalink)
TRD VVTi's Avatar
Gen5
That's strange. I did mine Saturday and only had to reset the clock. All the radio presets were still there.
If you disconnect the positive cable the entire car will lose power. You will have to reset everything.
Old 07-23-2008, 11:25 AM   #13 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gen6
I had to reset everything when i just disconnected the negative one. Your breaking the circuit either way.
Old 07-24-2008, 10:47 AM   #14 (permalink)
TRD VVTi's Avatar
Leaving the positive cable connected will still power circuits not grounded through the battery cable itself.
A simple experiment you can try would be to hook up a multi-meter or test light to the positive battery cable and ground it to something other than the car itself. You'll still have power without using the battery ground.
