Where we can buy the harness of spoiler LED light of a 2006 Toyota Camry? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2008, 07:25 AM   #1 (permalink)
2006 Toyota Camry LE
View castrocastro's Photo Gallery
My spoiler LED light does not come with harness to connect to the harness provided in the trunk. Any idea what type of connector I have to buy and where it is available? Thanks in advance.
castrocastro is offline   Reply With Quote
Old 07-13-2008, 01:32 PM   #2 (permalink)
netrickyaz's Avatar
View netrickyaz's Photo Gallery
just cut the harness and use splicers, its what i did. it's free that way. keep enough wire on the harness to reattach if you want some day
2005 Toyota Tundra Blue Steel Metallic (SR5® Access 4.7L i-Force V8 with VVT-i)
netrickyaz is offline   Reply With Quote
Old 07-13-2008, 01:41 PM   #3 (permalink)
There are three connectors I found
I found three free connectors (Harness) in the trunk. Any idea which one I should use for spoiler?
I am not able to make out which one is going to third brake light since in the spoiler spec it is mentioned connect to the third brake light..
Old 07-13-2008, 03:28 PM   #4 (permalink)
netrickyaz's Avatar
ok right like near the licensce plate but on the inside theres 2 for the license plate lights and one thats not being used. that is the one for the spoiler. thats what i have in mine at least. 06 camry LE
Old 07-13-2008, 03:43 PM   #5 (permalink)
Two connectors
In my car trunk (2006 CAmry LE), there are two connectors open on left and right of license plate light. Actually other wires from the same connectors are going to License plate light. So are you using the right connector for your spoiler light? Please let me know and thanks for your reply.
Old 07-13-2008, 04:04 PM   #6 (permalink)
netrickyaz's Avatar
ISEE NOW, i went and took a picture. you can use either one. here is an example.
Old 07-13-2008, 04:25 PM   #7 (permalink)
Forgive meee.
liquidi3ladz's Avatar
View liquidi3ladz's Photo Gallery
When I installed my spoiler the wire on the driverside didn't work. I ended up feeding a wire to the center brake light.
2002 Camry LE I4
liquidi3ladz is offline   Reply With Quote
Old 07-13-2008, 04:44 PM   #8 (permalink)
Thanks..Great effort..
Dear netrickyaz,
I really appreciate your effort for taking the picture and marking it..Great effort...You did a great job..
Thanks..
Old 07-13-2008, 04:44 PM   #9 (permalink)
netrickyaz's Avatar
hmm maybe the left one is not good then....idk mine works fine maybe a possible flaw or the left one is something else....im not sure. i was originally running a wire then i got the trunk took off the black part and kinda just went..OH!.... that was easy lol.
Old 08-03-2008, 08:20 PM   #10 (permalink)
fredberg's Avatar
View fredberg's Photo Gallery
Gen5 Spoiler LED's burned out?
A friend was following behind me one night and he noticed that a section of my spoiler brake light was not working. Sure enough, 4 LED's in a row are not working. I can't replace them individually. So it looks like I have to buy the whole piece? I'm thinking that piece will cost a fortune since it's an OEM specialty piece.
fredberg is offline   Reply With Quote
Old 08-03-2008, 08:39 PM   #11 (permalink)
Forgive meee.
^^ Slamming your trunk really hard causes that. I think it has to do with moisutre or losening of the bulbs. You should be able to find an LED strip on ebay. One thing to keep in mind is if that if your spoiler was an aftermarket part the warranty should cover the led bar (1 year).
2002 Camry LE I4
Old 08-04-2008, 05:05 AM   #12 (permalink)
fredberg's Avatar
Gen5
Arg! I can't find the LED strip on eBay, only the spoiler + LED strip. Any suggestions on my search?
