Easiest way to add sub/amp to 09 JBL HU? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2008, 05:47 PM   #1 (permalink)
View ben805's Photo Gallery
Gen6 Easiest way to add sub/amp to 09 JBL HU?
I have an amp and 12" sub that I would like to add to my 09 LE V6 with JBL 6 disc system, what is the easiest way to acomplished this? Does the JBL headunit has RCA output? should I splice into the rear speaker wires and tab them to line converter? if so...wouldn't it sound like arse? and from where should I be getting the remote turn on wire to the amp?
2009 Toyota Camry LE V6
2005 Toyota Camry SE V6
ben805 is offline   Reply With Quote
Old 07-13-2008, 06:12 PM   #2 (permalink)
View eclipsefirenos's Photo Gallery
i have an 07 with the jbl cd changer, and no, the stock hu does not have RCA inputs. the way i went was the line converter, but it still sounds good. as long the wires are done correctly, it should be ok. i had some pros do mine, so i was in the clear for that.
eclipsefirenos is offline   Reply With Quote
Old 07-13-2008, 06:27 PM   #3 (permalink)
GORILLAZ IN DA BAY
GORILLAKEV's Avatar
View GORILLAKEV's Photo Gallery
its really easy just put in a loc or hi/lo converter and tap it in to the rear speakers. with subs amp and wiring 2 to 3 hour project...bigloubumpin has a thread also he did with the stock deck also check it out 08 Camry LE - Amp,LOC & Sub Install(w/Pix & video) Pt.2...
CAR AUDIO REBUILD IN PROGRESS...2007 TOYOTA CAMRY SE I4.......
GORILLAKEV is offline   Reply With Quote
Old 07-13-2008, 09:30 PM   #4 (permalink)
do you guys know if these JBL 6x9 speakers are rated at 8, 4, or 2ohm? I'm also thinking about replacing them with slightly better stuff like the Infinity Reference 6922i.
Old 07-14-2008, 01:12 AM   #5 (permalink)
im pretty sure theyre 4 ohm. the rear speakers u can see, but the front ones ull have to take out to look at, and ive never done that
Old 07-14-2008, 09:03 AM   #6 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
I love all these pretty sures, maybes, I think ..............
The 6x9 door speakers are 2.2 ohms.
