5W-30 for 09 Camry? - Toyota Nation Forum : Toyota Car and Truck Forums
Closed Thread
Old 07-14-2008, 02:11 PM   #1 (permalink)
View Dragon88's Photo Gallery
5W-30 for 09 Camry?
I took my 09 Camry into the dealership today for an oil change. I'm at 2560 miles, I wanted to get an extra oil change in before the first scheduled maintenance. Afterwards, on my receipt I noticed they used 5W-30 oil, instead of 0W-20 or 5W-20 as recommended by Toyota. I asked the service adviser about this, he said they use 5W-30 as a common grade for multiple vehicles, have never had issues using this grade for Camrys, and that it's basically the same oil. They use Quaker State Synthetic Blend. Is this anything I should be concerned about?
On the plus side, they gave me no hassle about applying TSB-0068-08 after I stated hard shifting. The car feels a little more responsive on acceleration, especially after cornering. It's probably just placebo effect but I'm glad that I got it done.
Dragon88 is offline
Old 07-14-2008, 03:38 PM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
It won't hurt anything.
I would recommend that you bring your own oil from now on. 0W20 or 5W20 will actually make your engine more efficient.
What dealer did you go to?
2006 Camry LE Special Edition
TRD VVTi is offline
Old 07-14-2008, 03:43 PM   #3 (permalink)
View ben805's Photo Gallery
if you have V6 check your owner manual again, it stated 5W-30 should be use, and I believe 0W-20 and 5W-20 is suggested for i4. But 5W-30 work just fine on either engine, don't sweat it.
2009 Toyota Camry LE V6
2005 Toyota Camry SE V6
ben805 is offline
Old 07-14-2008, 07:08 PM   #4 (permalink)
I have the i4. I was thinking about taking my own oil next time, should I go with full synthetic? Also, is there any advantage to 0W-20 vs. 5W-20?
My dealer is Rick Hendrick in Fayetteville, NC.
Dragon88 is offline
Old 07-14-2008, 08:33 PM   #5 (permalink)
Blue Ribbon FTW!
fdexclpl's Avatar
View fdexclpl's Photo Gallery
Toyota released a TSB that stated 5W-20 was the preferred oil for its engines.
'07 Camry LE V6 - Blue Ribbon Metallic - 6-disc JBL - Moonroof
Someday I will list my mods here
Originally Posted by TRD VVTi View Post
I am a hater in one regard, I hate stupid.
fdexclpl is offline
Old 07-14-2008, 08:36 PM   #6 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
I would question the dealer and ask for another oil change for free.
Why should you have to pay for any extra gas consumption for the next 5,000 miles?????????
njerald is offline
Old 07-14-2008, 08:40 PM   #7 (permalink)
'07 XLE
Gen6
Just for the V6....................
njerald is offline
Old 07-14-2008, 08:48 PM   #8 (permalink)
My plan is to take in my own 5W-20 for the next scheduled maintenance, 2440 miles from now. However, is the difference in gas consumption substantial enough that I should make a fuss about it now with the dealer?
Dragon88 is offline
Old 07-14-2008, 08:54 PM   #9 (permalink)
'07 XLE
Gen6
Two-Three gallons over 12-15 fillups (~5,000 miles) is significant to me.
Maybe meaningless to you.
The bottom line - They didn't do what they were supposed to..............
njerald is offline
Old 07-14-2008, 09:13 PM   #10 (permalink)
Last time when I tried 5W-20 on my wife's 05 SE V6, the old oil pour out like running water when I changed it at around 3000 miles, the engine noise was slightly louder with the 5W-20 oil as well, no way in hell I would ever use it for our car again. I don't care what toyota recommended or says, IMO 5W-20 and 0W-20 is way too thin to be effectively protecting the engine in the summer heat. There are some researchs out there who had conducted fuel efficiency test on 5W-20 vs 5W-30 and the result was very disappointing, like less than 1% gain in mpg LOL BITOG forum is the best place to ask oil related question. Personally I am going to stick with 5W-30 be it V6 or i4
ben805 is offline
Old 07-14-2008, 09:19 PM   #11 (permalink)
'07 XLE
Gen6
5W-20 and the TSB does not apply to your '05............
njerald is offline
Old 07-14-2008, 09:42 PM   #12 (permalink)
TRD VVTi's Avatar
How an oil drains is meaningless. Engine clearances and the correct oil viscosity/weight mean everything.
The OP should use the correct _W20 weight oil, because that's what his vehicle calls for.
TRD VVTi is offline
Old 07-14-2008, 10:16 PM   #13 (permalink)
in the late 90s folks went with the OCI recommended by Toyota and look what happened....major oil sludge problem, just because Toyota say so does not mean they're always right, you guys do what you want with your car and use whatever you like. As i said, personally, me, myself...is going to use 5W-30 no matter what toyota recommended.
ben805 is offline
Old 07-14-2008, 10:20 PM   #14 (permalink)
'07 XLE
Gen6
Ignorance is bliss...........
njerald is offline
Old 07-14-2008, 10:49 PM   #15 (permalink)
Well, that's what irks me about this. Everything I buy/do for my car is good quality, no expense spared, and then I take it to a Toyota dealership for an oil change and they throw in some bulk oil of the wrong weight just to save a few pennies.
Dragon88 is offline
Closed Thread
