Originally Posted by pttrader
My 2002 Camry 4 cylinder engine makes a rapid rapping/tapping/rattling sound for 1-2 full seconds when I start it cold. It stops after the 1-2 seconds and does not happen when it starts warm. My mechanic said he has seen a couple instances when they solved it by installing a Toyota oil filter instead of another brand but that hasn't solved my problem after 5 days with the new filter. My friend advised me to add Slick 50. Any ideas? Thanks!!
How many miles are on the engine?
Have you had it since it was new?
Is the engine clean inside?
Where is the noise coming from specifically?
Can you post a video of the noise and location?
What oil do you use?
How long does it have to sit to make the noise?
No, don't add Slick 50. It won't help anything.
Originally Posted by djkor
hydraulic tappets maybe leaking down over nite maybe causing tappin for few secs on startup till the oil bleeds into them
The 2AZ-FE doesn't have hydraulic lifters.
They are adjusted with shims, not using hydraulics...
See page 14-7 and beyond:
http://www.camrystuff.com/manuals/Ge...Mechanical.pdf
