Cure for front end clunk/pop/rattle/thump noise with TRD springs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-20-2008, 05:17 PM   #1 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
I just changed the oil and rotated the tires on my Camry. I've had a front end clunk type noise that occurs when changing directions, turning, and accelerating. It occurred more often when turning and accelerating.
Here's how I fixed it:
1) Jack the front of the car up and remove the wheels. Be sure to let the front suspension hang. You will need the springs to be extended. Be sure to use jack stands under the subframe of the vehicle for safety.
2) Check the springs and note where coils rub each other when they are compressed (when there is weight on the front suspension).
3) Clean the area where the spring coils contact each other.
4) Apply grease or other lubricant to the area(s) where the coils are contacting each other.
5) Reinstall your wheels, lower the car to the ground, and torque the wheels to the proper specification.
6) Test drive your Camry and verify the repair. I'm confident that the noise will be gone.
I hope that helps many of the people with front end noise complaints and TRD springs. Good luck.
2006 Camry LE Special Edition
Old 07-20-2008, 05:20 PM   #2 (permalink)
Blue Ribbon FTW!
fdexclpl's Avatar
View fdexclpl's Photo Gallery
I'm going to try it out this week. Thanks for the tip!
'07 Camry LE V6 - Blue Ribbon Metallic - 6-disc JBL - Moonroof
Someday I will list my mods here
Originally Posted by TRD VVTi View Post
I am a hater in one regard, I hate stupid.
fdexclpl is offline   Reply With Quote
Old 07-20-2008, 05:22 PM   #3 (permalink)
TRD VVTi's Avatar
Gen5
My pleasure. Please post if it takes care of the problem. I'm sure that it will.
Old 07-20-2008, 07:36 PM   #4 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
got pics?
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
Old 07-20-2008, 11:31 PM   #5 (permalink)
TRD VVTi's Avatar
Gen5
Originally Posted by carlo$ View Post
got pics?
Sorry, I do not. I wasn't 100% positive that would fix the problem, plus it's so easy that I didn't feel pics were necessary.
Old 07-21-2008, 11:18 AM   #6 (permalink)
2004 Camry LE
somick's Avatar
Gameroom cash: $102015
View somick's Photo Gallery
What is going to happen when dirt and sand from the road stick to the grease?
Sam
2004 Toyota Camry LE
1999 Honda Accord LX
1992 Subaru Loyale
2010 Subaru Forester
somick is offline   Reply With Quote
Old 07-21-2008, 05:19 PM   #7 (permalink)
The Connoisseur
CharmCityES's Avatar
thanks for the tip TRD! that noise is fuggin annoying
i just wish i could figure out why my car feels so damn loose all the time...bumps make it feel so damn clunky
The "Executive Sedan"
Old 07-22-2008, 07:53 AM   #8 (permalink)
TRD VVTi's Avatar
Gen5
Sam
It will be pushed away from the spring contact points. Some will stick to the spring. That's better than noise in my opinion. You can't see the spring anyways...
Old 07-22-2008, 03:03 PM   #9 (permalink)
& JustAnotherCamry
View JustAnotherAsian's Photo Gallery
just to add- i had the same problem on all four corners and thought about the same thing. a little grease on the obvious contact points ("obvious" because there was a little scraping on some places of the coils) helped. after a few days, it practically cured itself.
i believe this is why tein ships certain spring packages with those rubber (or whatever material that is) sleeves.
JustAnotherAsian is offline   Reply With Quote
Old 07-22-2008, 04:54 PM   #10 (permalink)
TRD VVTi's Avatar
Gen5
My TRD springs have rubber type sleeves around the bottom coils, so do the factory springs on the '05 Highlander 4WD.
I looked at the Highlander springs and none of the coils touch each other. It would have been nice if TRD would have put the rubber farther up the springs.
Old 07-22-2008, 05:01 PM   #11 (permalink)
Blue Ribbon FTW!
fdexclpl's Avatar
My springs also have the rubber around the lower coils. It only covers about 1.5 of the coils.
Old 07-22-2008, 07:17 PM   #12 (permalink)
Camry Newbie
pedrojqc's Avatar
View pedrojqc's Photo Gallery
What Grease did you use?
2008 Camry LE with: Fog Lights/Inchannel Ventvisors/ 4300K HID/ Lip Spoiler/ Nokya Yellow 2500K Fog's/ All interior lightning white LED's / Front Strut Bar/ SE Grille/ K&N Typhoon Intake / TRD Springs / TRD 18" Wheels with 225/45/18 Michelin tires / Future Mod's:TRD Exhaust? ; Razzi Kit.
pedrojqc is offline   Reply With Quote
Old 07-22-2008, 09:22 PM   #13 (permalink)
LoudCamry's Avatar
Gameroom cash: $229327
View LoudCamry's Photo Gallery
i grease my spring today, and the noise seem to disapear, hope it stay like that
Thanks VVti for the tip!!
LoudCamry is offline   Reply With Quote
Old 07-23-2008, 11:07 AM   #14 (permalink)
TRD VVTi's Avatar
Gen5
No problem. I'm glad that it helped you out. The noise was really pissing me off. I can't stand things like that.
Old 07-23-2008, 11:48 AM   #15 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
+1 Todd, any particular type/brand of Grease you would suggest?
