2002 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-24-2008, 11:50 AM   #1 (permalink)
View tbclark1234's Photo Gallery
2002 Camry
Neither cigarette lighter socket has power, yet the fuze is good. Everything else seems to be working properly. Any ideas?
tbclark1234 is offline   Reply With Quote
Old 07-24-2008, 11:57 AM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Are you sure you checked the correct fuse? Which one did you check? How did you check it?
2006 Camry LE Special Edition
Old 07-24-2008, 12:14 PM   #3 (permalink)
I checked the 15 amp fuze in the fuze panel to the left and below the steering wheel. I checked it with an ohmmeter.
Old 07-24-2008, 02:03 PM   #4 (permalink)
TRD VVTi's Avatar
Gen5
Once again, which fuse did you check?
Old 07-24-2008, 02:13 PM   #5 (permalink)
Sorry, it was the fuze labeled "CIG".
Old 07-24-2008, 02:37 PM   #6 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
Try a 15A labeled either 'power point' or 'power outlet'. I'm going off memory here, but if I'm correct the two power outlets don't run off the 'cig' fuse, that's an optional circuit.
And just for reference, a 'fuse' is a component in a circuit to protect from over draw, and a 'fuze' is something that helps initiate an explosive device, like an FMU-152 inside everyone's favorite JDAM.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 07-24-2008, 04:13 PM   #7 (permalink)
That's it - the 15 amp fuse labeled "Power Point" was blown. Thanks for the fuse vs. fuze explanation. I should have known that.
