Originally Posted by ironwill2006
I want to swap the bulbs, put in red or amber led's. I can't figure out which bulbs I need. I know I need 3057's for the bottom, but whats the small bulb at the top of the tail light? Leaving the turn signal and clear park light? alone. I thought 921's but the rear turn signal bulb doesn't seem to be the same as the top one. There are no markings on the stock bulb. I don't get it. Anyone swapped these bulbs? Also what colors did you guys use and how do they look?
if you go to any autoparts store, there is a little book, that tells you what bulb size you need for any of the bulbs in your entire car including the tails... good luck and post some picts...
