Originally Posted by njerald
Good God, DON'T use a torch!!!!!!!!!!!!!!!
If you want to try heat, use a hand held hair dryer...........
u can get away with using a torch... hairdryer will take forever to heat the material in order for it to be pliable...
however, njeralds warning is applicable... use extreme caution... if it gets too hot, it will start to melt, and the paint will bubble...
the way i did it, was with quick passes, over the area, and with each pass, i applied pressure to see if the material was becoming pliable (i was wearing thick leather gloves while testing for pliability...
edit: i just looked at the picture... if you want it to look perfect go a head and replace... but heating it and pushing it out, will get the dent out... but the paint damage will still be there....
