smoke - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2008, 07:57 AM   #1 (permalink)
View elmasduro's Photo Gallery
smoke
hi, i have a toyota camry le 2002 with 143k miles. when the car is sitting there the whole day and i go turn it on the next day, there a large amount of smoke coming from the muffler. the color is regular, gray. then i can turn off the engine and turn it on and will not do it again. it only does it when the car is sitting for a long time. usually, the next day when i go turn on the car. is this normal?
elmasduro is offline   Reply With Quote
Old 07-28-2008, 08:00 AM   #2 (permalink)
View Kingdom934's Photo Gallery
By any chance, does this only happens when it is in the morning 'ish' and/or cold?
If so, its normal
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 07-28-2008, 09:09 AM   #3 (permalink)
Asteroid's Avatar
View Asteroid's Photo Gallery
Is it steam or smoke? If it's steam this is normal on cold mornings from the cat converter. If it smells like smoke (oil burning) then you have an engine problem (rings or valve stem seals).
04 ACV36R Camry Sportivo 4cyl manual
92 CE100 Corolla DX diesel (jdm import) *sold*
Asteroid is offline   Reply With Quote
Old 07-28-2008, 09:22 AM   #4 (permalink)
Joined the dark side. :D
Gameroom cash: $654791
View workerant's Photo Gallery
If it's from burning oil than the smoke would continue right? And 2nd start would produce the same "smoke" right?
Look like it's water condensation so it's normal. Nothing to worry about.
workerant is online now   Reply With Quote
Old 07-28-2008, 10:36 AM   #5 (permalink)
the smoke only happen in cold start. it could be in the morning or afternoon. if i use the car and then turn it on for second time, it will not happen. usually it happens the next day when i turn on the car for the first time that day.
is this normal?
Old 07-28-2008, 11:40 AM   #6 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Try the "Newbies please read before posting!" sticky at the top of this forum.
You are started threads on topics that are frequently covered and just adding to the clutter.
Your problem sounds like valve seals. It's common on vehicles that aren't properly maintained.
2006 Camry LE Special Edition
