Alot of you have asked me how to remove the lower resonator. So here it goes. Note: i nor this site are liable for any damage you cause to your car in the process of doing this. also, the 1st time you go to start it when your done, it will probibly just stall right out. Just start it again and it should run fine. Just let it idle in drive for a few mins. And take it around the block once or twice
Step 1: Get your tools. Ratchet, 10mm ratchet attachment, and 10mm wrench, and a flat head screw driver.
Step 2: Remove all clips holding the radiator cover on. To do this you simple push the center of them in, and pull them out. This is what it should look like once removed.
Step 3: now that you have all of the clips out. You can get the radiator cover out and place it aside
Step 4: Remove the 2 outer most bolts on the intake with the socket wrench
Step 5: you can now pull the top section of the intake off. Be sure to unclip the vacuum lines and wires that are connected to it
step 6: Now remove the bolt that is holding the lower intake. You can then pull the lower intake out.
SIDE NOTE: at this point you should have these parts removed. Radiator cover, upper intake, and lower intake.
Step 7: Now its time to remove the battery. First remove both leads from the battery terminals with the 10mm wrench. Be sure to disconnect the negative batter cable first, and install the negative battery cable last. It's safer that way.
This is what it should look like with the leads removed.
Now you LOOSEN the nut that is closest to the air box. DO NOT REMOVE IT
Once you have it lose enough to where u wan wiggle the back part of the battery holder, you can remove the bolt on the front of it
This is what the battery and battery harness should look like once removed.
Step 8: you now have a clear view at the resonator. So you can now remove the bolts holding it in. The one on top u can remove using the socket wrench
Now that you have that bolt removed, there is a plastic screw that you can just pry out with your flat head screw driver.
You can now remove the resonator.
You can now put everything back together (except the resonator of course) I personally do it in this order. Lower intake, upper intake, battery, then radiator cover. To get the clips ready to hold the radiator cover in, push the bottom of them in until they look like this:
Then, you put them in the hole, and push in until they click.
