Gas Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2008, 01:55 PM   #1 (permalink)
B0R1CHA
b0r1cha's Avatar
Gameroom cash: $125535
View b0r1cha's Photo Gallery
Gas Question
So my mom has the Lexus Rx350. i tihnk the 07 model. anyways iw as wondering would it be THAT bad to put in 87 octane rather than 91?
19x8.5 +35 Axis Hiro for sale
b0r1cha is offline   Reply With Quote
Old 07-28-2008, 02:04 PM   #2 (permalink)
Joined the dark side. :D
Gameroom cash: $654791
View workerant's Photo Gallery
It's GOOD to save $$$. Unless the manual said the car need 91.
workerant is online now   Reply With Quote
Old 07-28-2008, 02:37 PM   #3 (permalink)
Gameroom cash: $303755
^ Exactly. GO with what the owner's manual says. If it says it requries 91 octane, it may ping on 87. If the manual states that 87 octane may be used, you have been wasting money on 91 octane.
Mike
Mike Gerber is online now   Reply With Quote
Old 07-28-2008, 02:45 PM   #4 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
The reason it says it requires premium is because as Mike said, the car wrongs optimally on 91+ octane, and using lower rated octane may cause pinging/knocking. I'd bet though that since it's an '07 Lexus, they expect some people will use regular so it would probably knock down the timings to accommodate for the difference, but again that's just what I think.
geoff5093 is offline   Reply With Quote
Old 07-28-2008, 02:49 PM   #5 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Mike
+1
You probably wouldn't hear it, but the computer would see it. Performance would suffer if the car's designed/programmed for the higher octane. Usually when performance/efficiency suffers, so does fuel economy.
2006 Camry LE Special Edition
Old 07-28-2008, 05:53 PM   #6 (permalink)
B0R1CHA
b0r1cha's Avatar
hmm ok i guess its best to just use 91 octane then. haha. just thought i would ask and see.
Old 07-28-2008, 05:54 PM   #7 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
The manufacturers advertise a certain mpg rating, a certain horsepower and torque rating, and all of this is related to the octane rating of the fuel used in the tests. If they said openly that it was ok to operate with 87 octane instead of 91 then they would be stepping on their own toes with respect to mileage and performance, so they don't. But the car will in all probability run just fine, less a couple horsepower, and will not ping, knock, or cause other problems. It should run just fine.
Now, having said that, it IS possible to drop the octane rating down to the point of causing a knock. Some years ago I had to settle for a tank of Nova at the friendly Pemex station. They were out of anything above 76 octane, so Nova it was. Thought the valves were going to fall out until I got up the coast to Veracruz where I found much better fuel. They don't make Nova any more!!
gdanaher is offline   Reply With Quote
Old 07-28-2008, 08:34 PM   #8 (permalink)
geoff5093's Avatar
Around here 91 octane is generally just 10 cents more per gallon then 87, so you are only looking at $1.5-$3 more for a fill up.
Old 07-28-2008, 08:53 PM   #9 (permalink)
View coolbeans's Photo Gallery
Lucky you... where i live its 91 is usually 20cents more, some times 25 cents more if ur really having a sh!ty day....
coolbeans is offline   Reply With Quote
Old 07-28-2008, 09:46 PM   #10 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
whats the owners manual say
CamrySExxx is offline   Reply With Quote
Old 07-29-2008, 01:03 AM   #11 (permalink)
B0R1CHA
b0r1cha's Avatar
havent read the manual but on the gas cover thing it says premium fuel only. which i know i should follow, but i was just wondering about the downfalls of using 87 octane.
Old 07-29-2008, 08:35 AM   #12 (permalink)
^ just follow what the car is recommended to run on. As others said you will probably experience pinging
Old 07-29-2008, 08:45 AM   #13 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $462074
View BlackCamSe's Photo Gallery
you could if you wanted to. The car would probibly require a carbon cleaning a little more often though.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 07-29-2008, 12:13 PM   #14 (permalink)
TRD VVTi's Avatar
Not true.
Old 07-29-2008, 01:03 PM   #15 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gen6
Originally Posted by TRD VVTi View Post
Not true.
not true? ive herd that from an ASE master tec. Are you one?
