2009 Camry XLE- Air conditioner noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2008, 04:38 PM   #1 (permalink)
View tejas.kary's Photo Gallery
Talking 2009 Camry XLE- Air conditioner noise
Hi,
I am a relatively new member on this forum. Bought a 2009 Camry XLE (V6 ) a couple of months back.
While cooling I sometimes feel some noise within the cabin coming from the AC. The noise is noticeable in the front cabin with moderate volume of the music. I am not sure if this is normal or I should get it checked from my dealer.
Thanks in Advance!
tejas.kary is offline   Reply With Quote
Old 07-28-2008, 05:12 PM   #2 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
??? I guess you are not referring to the change in fan noise when you keep it on auto A/C? Anything rattling or strange vibrating...take it to the dealer and demonstrate it to the tech before you drop the car off.
"Just for Fun" http://www.cardomain.com/ride/2973919
Tobeit is offline   Reply With Quote
Old 07-28-2008, 05:17 PM   #3 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Gameroom cash: $819821
iTrader Score: 16 reviews
View GT-R's Photo Gallery
What does the noise sound like? A blowing sands noise or something? Cause mine sounds like sands got stuck inside when the A/C is blowing high.
GT-R is offline   Reply With Quote
Old 07-28-2008, 05:19 PM   #4 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
If it's a static sound coming out of the drivers side vent, maybe your Plasmacluster is working................
Old 07-28-2008, 05:30 PM   #5 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $610131
View Zembonez's Photo Gallery
On low fan speed setting, it is sometimes possible to hear the freon circulating through the expansion valve, It sounds a bit like air escaping under pressure or sometimes like water running through a pipe.
Is this what you are hearing.
Zembonez is offline   Reply With Quote
Old 07-28-2008, 06:56 PM   #6 (permalink)
Probably this might best describe it. I'll see if this happens only when the AC is blowing high.
Old 07-28-2008, 10:01 PM   #7 (permalink)
Take it easy... :-)
Tobeit's Avatar
...that would be the first report that this thing actually exists and works.
Old 07-28-2008, 10:03 PM   #8 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Reverse feedback oscillators have been known to cause problems. I'd have that checked right away. Blinker fluid reservoirs were eliminated on your model.
