So I'me having issues with my engine. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-29-2008, 10:23 AM   #1 (permalink)
Toyota
View farzien's Photo Gallery
Well it all started a week or so ago, when I noticed very little bluish upon start up from the exhaust pipe. Fast forward to two days ago and there is a lot more whitish, bluish smoke during startup. I decided to check the oil levels that same day, and I found that almost 90% of the oil had been (i'm assuming) burnt off, the remaining oil was burnt. I have also noticed a loss of power, which im assuming is a result of having almost no oil. I decided to call my mechanic, and I told him the symptoms; he said it is a very common problem with Toyota, and he believes that I have a head gasket problems. He says that it could end up costing up to $1,200 to repair, What do you guys think? Thanks for your help.
farzien is offline   Reply With Quote
Old 07-29-2008, 10:30 AM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
He could be right.........
Old 07-29-2008, 10:56 AM   #3 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $462074
View BlackCamSe's Photo Gallery
dont drive it with almost no oil! Or you could add a new engine to that repair.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 07-29-2008, 11:04 AM   #4 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Gameroom cash: $819821
iTrader Score: 16 reviews
View GT-R's Photo Gallery
What kind of car? Is it still under warranty?
GT-R is offline   Reply With Quote
Old 07-29-2008, 11:08 AM   #5 (permalink)
Joined the dark side. :D
Gameroom cash: $654791
View workerant's Photo Gallery
Yep, better to drive it with no oil so can add a new car instead.
workerant is online now   Reply With Quote
Old 07-29-2008, 11:10 AM   #6 (permalink)
View ny_transplant's Photo Gallery
No claim of an expert here, so with that said:
When the head gasket goes, doesn't the coolant mix with the oil? I thought you would see a foamy residue on the dipstick as a result.
Could it be just the rings on the pistons?
ny_transplant is offline   Reply With Quote
Old 07-29-2008, 11:16 AM   #7 (permalink)
Toyota
Well guys, after I found out there was almost no oil, I added 5 bottles immediately; I wasnet going to let my engine burn out. By the way it is an 02 Se V6 it has a 3.0L. My mechanic said that the car should still run for a couple more years before having any major problems. I might start looking at a replacement....
Old 07-29-2008, 11:59 AM   #8 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
I'm guessing the the valve seals are bad and the engine is worn from lack of maintenance.
Usually simple oil changes keep these kind of things from happening....
2006 Camry LE Special Edition
Old 07-29-2008, 12:18 PM   #9 (permalink)
Toyota
TRD VVTi, I have performed regular maintenence on the car since I bought it in 02. I have strictly used the maintence plan that is provided with the owners manual. And as for oil changes, I have changed my oil every 5,000 miles with a semi synthetic since I purchased the car. So please dont tell me that I dont take proper care of my cars. The whole reason I posted here is because I am amazed how within 2,500 miles most of the engine oil cooked. Now I obviously dont know what is exactly what is wrong with the car, which is why I have seeked your guys' advice. Please keep your advice comming. Do you guys think its worth repairing? The car has 125,000 miles.
Old 07-29-2008, 12:55 PM   #10 (permalink)
Would a compression and/or leak down test pinpoint the issue to rings or seals?
Old 07-29-2008, 12:58 PM   #11 (permalink)
Asian N00b Modder
Gellenole's Avatar
View Gellenole's Photo Gallery
wow that's about double my mileage -- and you only have an 02?
1995 Camry I4 @ 123k Miles - RIP 5-26-07
[Silverado Backed into it]
Originally Posted by catric69 View Post
It's cheaper if you get a new gf.
Gellenole is offline   Reply With Quote
Old 07-29-2008, 01:04 PM   #12 (permalink)
TRD VVTi's Avatar
Gen5
I didn't tell you that.
Reread my reply:
You didn't provide information that would make me think otherwise. Usually this doesn't happen when an engine is maintained properly.
I'm sorry that I didn't hug and hold you when I posted my reply... I guessed that you were a mature adult and not a small child.
Old 07-29-2008, 02:03 PM   #13 (permalink)
Banned
View TRD_EarBanger's Photo Gallery
personally i honestly I try to act like man and not baby
TRD_EarBanger is offline   Reply With Quote
Old 07-29-2008, 02:59 PM   #14 (permalink)
Toyota
Sorry if I over reacted TRD VVTi its just that this problem is really pissing me off right now, The thought of spending $1500 on a problem that should not be happening is not very appealing. I also wanted to know if anyone has had an issue like this on their camry or any other toyota as my mechanic said it is very common; I personally have never heard this claim before.
Old 07-29-2008, 03:03 PM   #15 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Hey, you know, with $1500 down and $200 a month you can get the 09 LE here in Cali. Plus you can just trade in your car, it'll break down again anyways, no matter how many times you fix it. IMO, anything that's over 100K needs to go. I know most people here have over 200K, but it's not me.
