Vibration while braking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-29-2008, 06:11 PM   #1 (permalink)
View rkelachim's Photo Gallery
Hi all:
I have an '02 Camry. For a while now, it has had a very noticable "shimmy" in the steering wheel while braking. It is most noticable at about the 30-45 mph range when braking.
This weekend, I replaced what I thought to be the most obvious culprit - the front rotors. So now with a new set of front rotors, still does the exact same thing.
Anyone have some other ideas as to what might be causing this "shimmy" in the steering wheel? Rear brake drums maybe?
rkelachim is offline   Reply With Quote
Old 07-29-2008, 06:24 PM   #2 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
Hmmm...this is very strange how you still get the vibration even AFTER new front rotors.
Do you have any flat spots on your tires?
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 07-29-2008, 10:59 PM   #3 (permalink)
View hans747's Photo Gallery
good poind. if your tires are out of balance or have poor wear you will get that problem.
hans747 is offline   Reply With Quote
Old 07-30-2008, 07:51 PM   #4 (permalink)
View ben805's Photo Gallery
I hope you replace the pads along with the new rotors. Other than the wheels out of balance, while you're at maybe it's a good idea to get the front/back alignment check as well.
2009 Toyota Camry LE V6
2005 Toyota Camry SE V6
ben805 is offline   Reply With Quote
Old 07-30-2008, 08:02 PM   #5 (permalink)
View toyomoho's Photo Gallery
Check for a warped hub or debris between the hub and rotor where they mate up.
Old 07-31-2008, 05:44 PM   #6 (permalink)
RED07CAM's Avatar
View RED07CAM's Photo Gallery
Hey I have the problem in my 07 the Camry's brakes are a bit soft brake hard with them they heat up an the rotors will warp.What I did was instead of using OEM rotors I upgraded to a set of Brimbo OEM replacements they cost a little more but they can take the heat.
RED07CAM is offline   Reply With Quote
Old 07-31-2008, 06:20 PM   #7 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Originally Posted by RED07CAM View Post
Hey I have the problem in my 07 the Camry's brakes are a bit soft brake hard with them they heat up an the rotors will warp.What I did was instead of using OEM rotors I upgraded to a set of Brimbo OEM replacements they coast a little more but they can take the heat.
I'm all for coasting more................
Old 07-31-2008, 07:41 PM   #8 (permalink)
JACK_FROST's Avatar
View JACK_FROST's Photo Gallery
LOL...
JACK_FROST is offline   Reply With Quote
