OEM wheel width - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-01-2008, 03:05 AM   #1 (permalink)
fredberg's Avatar
View fredberg's Photo Gallery
Gen5 OEM wheel width
i have 15" OEM steel wheels. im jus wondering if an aftermarket 15" wheel (of any reputable brand i.e. Montegi, Enkei, etc) would have a wider width than OEM.
jus wondering, becuz im thinkin of doing a swap, keeping the wheel size the same. i know u may think im crazy for not plus sizing, but i like the ride of the taller tires.
fredberg is offline   Reply With Quote
Old 08-01-2008, 10:40 AM   #2 (permalink)
View TRDGen5.5camry's Photo Gallery
stock 15" rim are 15X6.5 +45offset
after market rim are 15X6.5 and 15X7 any offset you want
hope this help
TRDGen5.5camry is offline   Reply With Quote
Old 08-02-2008, 02:50 PM   #3 (permalink)
fredberg's Avatar
Gen5
thnx 4 the info. if stock width is 6.5", can i only use aftermarket wheels that are 6.5" wide? or can i use 7" also?
one more question, this might sound dumb. but im assuming with the same diam wheel swap, will PSI be same as OEM (which is 29 PSI front and rear).
Old 08-02-2008, 02:57 PM   #4 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $610131
View Zembonez's Photo Gallery
I think you are crazy for not using the English language. Are they charging you by the letter to use that keyboard?
BUT... the factory steelies on mine were 6.5" wide. Most A/M wheels are going to be 7 inches or wider.
EDIT: You can use a 7 inch wide wheel and use your old tires - no problem.
Zembonez is offline   Reply With Quote
Old 08-02-2008, 05:01 PM   #5 (permalink)
Forgive meee.
liquidi3ladz's Avatar
View liquidi3ladz's Photo Gallery
PSI won't change
2002 Camry LE I4
liquidi3ladz is offline   Reply With Quote
