While changing my oil, and I took a look at the bottom of the transmission case and I noticed a drop of oil.
My car is an '07 Camry CE I4 manual transmission, 14k miles.
The oil seems to be coming from where the rust-colored output drive shaft comes out of the transmission, and I think it is engine oil. You can see the oil runs all the way down out from the where the drive shaft comes out of the tranny down to bottom point of the tranny. See the golden-colored drop of oil at the bottom left, below the tranny drain plug. It is a small leak, but still a leak.
I will be taking it to the dealer for repair, but I wanted more info on what they need to do and what to call the parts, etc. so I sounded intelligent.
At first, I thought the area where the leak is coming from would contain transmission oil, but the drop sure looks like engine oil? Which is it?
Thanks in advance!
