I had the exact same problem with my 02 camry. It was the belt tensioner bearings that were going out. I had to replace it, and by the time I found out what it was it failed the exact day I was going to fix it. That was the only time the camry ever left me stranded, so be careful. It should sound like that for about 6 months and no one can help you locate it until it gets worse, once it is worse it goes quickly. Good Luck
P.S. I had to change the tensioner at about 104000 miles so if you are close, I wouldn't be surprised if it was the tensioner.
