Bigger Rims = Bad Ride? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-04-2008, 08:26 PM   #1 (permalink)
Profound!
View mwfromva's Photo Gallery
OK, so I bought an 09 LE because I personally am not too fond of the harsher ride of the SE. My worry now, is that if I upgrade the rims (was thinking 18"), will it make a huge difference in the smoothness of the ride?
Any input from those who have an LE or XLE and have put on aftermarket wheels and tires?
08 Black Highlander Sport AWD
09 Blue Camry LE 4cyl
mwfromva is offline   Reply With Quote
Old 08-04-2008, 08:50 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Bigger rims won't hurt you but keeping the same OD/circumference of the new tire means less cushion between the road and the wheel.
Old 08-04-2008, 09:11 PM   #3 (permalink)
wetherburner's Avatar
View wetherburner's Photo Gallery
Njerald is right - and keep in mind that going to 18's will not have a drastic negative effect to your ride quality.
Here is a great website I was referred to by another TN member, which I used when determining the appropriate tire size and offset for my new rims/rubber...
http://www.rims-n-tires.com/rt_specs.jsp
wetherburner is offline   Reply With Quote
Old 08-04-2008, 09:14 PM   #4 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
I have an XLE with TRD and 18" and the mentioned lower profile tires - if any, it makes the ride better, less cushioning, but better handling for me.
"Just for Fun" http://www.cardomain.com/ride/2973919
Tobeit is offline   Reply With Quote
Old 08-04-2008, 09:20 PM   #5 (permalink)
The O-Sho
Omer's Avatar
View Omer's Photo Gallery
OT: Where in VA are you from?
http://www.cardomain.com/ride/2456437
2007 Camry LE (Magnetic Gray Metallic)
Mods: 6000K Apexcone HID Kit, Interior Footwell LEDs, Chrome Grille Accents, Kydo 9005 Hyper White High Beams
Omer is offline   Reply With Quote
Old 08-04-2008, 09:25 PM   #6 (permalink)
it is what it is
akira751's Avatar
View akira751's Photo Gallery
Gen6
I see that you have a 08 Highlander sport, some people feel that the sport has a harsher ride than the base or Ltd. Did you feel a difference?
07 Camry SE V6, Nav Mag Grey,18" Nex-0 gun metal, Trd Springs,K&N Typhoon Intake
http://www.cardomain.com/ride/2475669
akira751 is offline   Reply With Quote
Old 08-04-2008, 09:25 PM   #7 (permalink)
Profound!
Midlothian - I see you're close!
Old 08-04-2008, 09:32 PM   #8 (permalink)
Profound!
YES. And during our 20 minute test drives, I felt the tighter handling of the Sport was a bonus over the softer ride of the Limited, especially considering it was a taller SUV. However, in retrospect, I wish we would have gone with the Limited. The Sport rides nice, but expansion joints and potholes can be quite jarring.
I'm glad you asked, because the Highlander really is the basis for me asking this question. I honestly have wondered why the Limited has 19" wheels - I think 18" wheels would be sufficient, and provide a greater overall comfort level.
At any rate, I guess if I went to a larger wheel, a tire with similar sidewall height would keep the ride in check, however I'm concerned about 2 things. Speedometer re-calibration (easy?) and unsprung weight of the wheels and tires. I'm not sure how much the stock steel wheels and tires weigh, but I imagine that a larger wheel and tire would add quite a bit of weight to the vehicle.
Old 08-04-2008, 09:35 PM   #9 (permalink)
Profound!
What's the stock offset? 16"?
Old 08-04-2008, 09:38 PM   #10 (permalink)
I'll let someone more qualified than me who has an LE comment on what the stock offset for your specific vehicle, but I can tell you that I went with a +35 offset on my 18's (225-45-18) and it kept my speedometer pretty darn close to the OEM tire/wheel specs (I have an 07 SE-V6).
Just play around with the link I sent you once you have the stock specs, and you won't need to recalibrate your speedometer....
Old 08-04-2008, 09:49 PM   #11 (permalink)
Profound!
Is 40mm offset too much?
Old 08-04-2008, 10:40 PM   #12 (permalink)
it is what it is
akira751's Avatar
Gen6
Nope.
Old 08-04-2008, 11:20 PM   #13 (permalink)
The O-Sho
Omer's Avatar
Yep, nice.
Actually went to Clover Hill HS in Midlo, and I'm in that area a lot.
Old 08-05-2008, 04:34 PM   #14 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
why did you get a Se if you dont like the ride of it, anyways I have 18s and you wont feel a difference between the stock 17s and 18s
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 08-05-2008, 07:53 PM   #15 (permalink)
View Big05Taco's Photo Gallery
MW got an LE, not an SE
'05 Silver Tacoma Double Cab 4x4 TRD Sport - sold 4/5/08
'09 Classic Silver Metallic Corolla S GEN X - sold 3/27/2009
'08 Classic Silver Camry SE V6 GEN 6
Big05Taco is offline   Reply With Quote
