05 Camry Rear Sway - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-08-2008, 01:02 PM   #1 (permalink)
View XPS9000's Photo Gallery
Gen5 05 Camry Rear Sway
I am planning to purchase the TRD Rear Sway Bar from the Dealer. And I was wondering if any of you guys can help me out on how to install it and the right tools to use. Also the specs to set the right stiffness for maximum handling. So I don't have to cough up 160 for install!! Hope you can help.
XPS9000 is offline   Reply With Quote
Old 08-08-2008, 01:43 PM   #2 (permalink)
The Connoisseur
CharmCityES's Avatar
its a fairly easy install....do a quick search and there might be a DIY on it around here
to my knowlege all you need is a 12mm socket for the sway bar mount bolts (3 on each side) and a 14mm wrench for the sway bar links (1 on each side), and a set of allen wrenches in case the sway bar link bolt decides to twist with the nut...
be sure to remove the rear wheels as well, because it makes removing the old bar and installing the new one much easier.
The "Executive Sedan"
Old 08-08-2008, 05:48 PM   #3 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
As stated above, do a search as the topic has been covered several times. There is a "Newbies please read before posting!" sticky at the top of the forum that explains how to use the search function.
I installed my TRD RSB on the Autocross setting and it works perfectly. I backed my car onto some ramps and swapped out the bar without removal of the tires. It's a simple job that only takes a few minutes.
2006 Camry LE Special Edition
Old 08-08-2008, 08:12 PM   #4 (permalink)
Forgive meee.
liquidi3ladz's Avatar
View liquidi3ladz's Photo Gallery
If your good on your back.. you don't even need to lift the car or remove a wheel.. The stock swaybar just comes right off.
2002 Camry LE I4
liquidi3ladz is offline   Reply With Quote
