Transimission problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2008, 02:32 PM   #1 (permalink)
View onavi's Photo Gallery
Gen5 Transimission problem?
On my 2003 Camry, 4cyl, in the past week, when slowing down to a stop, the car is making a jerking motion. It feels like you are running over something. It doesn't do it every stop though. Is this something I should worry about?? The transmission was flushed last summer, its been about 8k since thean, the fluid doesn't smell burnt at all, slightly brown in color.
TIA!
onavi is offline   Reply With Quote
Old 08-14-2008, 03:13 PM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
If the transmission fluid is slightly brown I'd recommend that you change the fluid. If you have it flushed do not use any chemicals when flushing the transmission fluid. Use only the proper fluid.
Is the MIL on?
If the MIL isn't on you may want to reset the ECU.
2006 Camry LE Special Edition
Old 08-14-2008, 03:58 PM   #3 (permalink)
I'll try resetting the ECM and see what happens. I got a case of the T4 ATF so i will try draining the transmission this weekend. When it was flushed, I don't think it was a chemical flush, just flushed with fluid. The dealer flushed the transmission when I bought it in complaining of hard shift at higher RPM's. They stated that is was normal due to different pressure in the torque converter and the transmission, or something like that. I forgot what the paper stated. I'm just worried that it will go out, once the powertrain is outta warrenty in October.
Old 08-14-2008, 05:24 PM   #4 (permalink)
TRD VVTi's Avatar
It would be a good idea to have the dealer check it out and verify your concern. That way if there is a problem just outside of the warranty period you may be able to get any problem with the transmission good willed.
Old 08-15-2008, 05:13 AM   #5 (permalink)
I tried resetting the ECM, no luck, the car has not relearned its idleing yet, I might have to reset it again. With the A/C the car is vibrating really bad at a stop light. The problem is happening when slowing down and you can hear/feel it at 16 MPH. When its hot outside, you can hear and feel it like 85% of the time when slowing down. At night, maybe half the time, you can feel it not as bad though. Not sure if I want to drain the transmission and see if it goes away, or just take it in next week as it is.
Old 08-15-2008, 03:51 PM   #6 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $462074
View BlackCamSe's Photo Gallery
sounds like its the 2nd to 1st downshift giving you problems. Take it to the dealer or a good trans shop and have them look at it.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 09-09-2008, 11:27 PM   #7 (permalink)
Gen5
of course the problem didn't happen when I took the car into the dealer. they drove the car twice and I drove it with the service adivser, It might have done it once when I was i driving it but the road was bumpy, so I'm not sure.
I am now convinced its the transmission cause if I turn off overdrive, it doesn't jerk.
Old 09-10-2008, 12:22 AM   #8 (permalink)
just a nobody
Does this happen after you have been driving on the highway at a steady speed for some distance?
N.E.O.
Old 09-10-2008, 12:29 AM   #9 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
Good will warranty repair? The only kind of "will" that Toyota has is "bad will" which it doesn't hesitate to share even when someone's clearly still within warranty. It's a good suggestion that you made, but it won't work with this car brand.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 09-10-2008, 03:43 AM   #10 (permalink)
it seems to be doing it mostly during the day, when its warm outside, I do half of my driving at day, other half at night, and its during the day when you feel the car jolt when you slow down.
it started doing this after a trip up to vegas a few weeks ago. maybe the strain going up the hills damaged something in there.
Sometimes the car shifts hard under acceleration, the RPM's go up but the car doesn't speed up like it should. This happens when you go to pass/speed up.
I looked in the service book and it seems like the tranmission shifts 3 to 2 at 11 to 15mph. I dont have the slightest idea on how the gear box works, not sure what gear I am in at whatever time.
I want to get this resolved before Oct since thats when the powertrain warrenty is up. The service advisor did say least I brought it in and its documented if something happens once the warranty is up. I dont wanna get stuck with a 2k+ repair bill in 3 or 4 months
edit:
it will do it right away from a cold start. you have to accelerate the car up to past 35 to get it to jolt. you can really feel it when you are going down hill. feels almost like someone runs into the backend of the car.
