Battery recommendations? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-15-2008, 08:58 AM   #1 (permalink)
View achates1's Photo Gallery
Does anyone have any tips for getting a good deal on a new battery for my 2002 Camry? Or anything to be aware of when installing it?
achates1 is offline   Reply With Quote
Old 08-15-2008, 09:09 AM   #2 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $610131
View Zembonez's Photo Gallery
Buy the recommended battery from a major auto parts chain and hold on to your receipt. Most will install for free. By buying from a nationwide chain, you have a warranty wherever you travel,,, just in case you ever need it. Batteries are relatively trouble free items for at least 3 years.
Zembonez is offline   Reply With Quote
Old 08-15-2008, 10:28 AM   #3 (permalink)
Joined the dark side. :D
Gameroom cash: $654791
View workerant's Photo Gallery
Good batteries are Red Top or Yellow Top from Optima Battery. Do a little Google for more info.
Of cause the battery is only good if you provide it the conditions that it design for... which are to keep it fully charge or over charge.
workerant is online now   Reply With Quote
Old 08-15-2008, 11:10 AM   #4 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Gameroom cash: $819821
iTrader Score: 16 reviews
View GT-R's Photo Gallery
I would stick to Toyota OE batteries. I had Energizer on my '00 Corolla, and it seems kinda weak. Sometimes my horn will not work, and sounds weak. But when the engine is runnning, it sounds normal.
When installing it, make sure you pay attention to the position of the bracket (that 1 metal piece that holds the battery), screws, etc. before removing it. Sometimes it's a bit tricky when reinstalling the bracket, also remember to tighten every screws, especially the connectors.
GT-R is offline   Reply With Quote
Old 08-15-2008, 11:31 AM   #5 (permalink)
O really?
LOL.. it was recommended by TRD to remove the negative only. Somehow that doesn't cause things to get reset. It goes against my logic and I haven't tried it yet so can't say but it shouldn't hurt anything.
Camry GT-R, I think your problem is you installed a battery with a lower CCA (cold cranking amp). Bigger engine require higher CCA battery to turn it. They also have the CA rating but usually that info is almost useless.
Once the engine start, it is your alternator that take over and the battery go into charging state. Of cause for long trip, the battery almost constantly get over charge but they design to withstand that (unlike most other batteries).
Once, a coworker even demonstrate it to me by start up his car and disconnect one of the battery terminal to show me. The engine kept running with one of the terminal disconnect.
Old 08-15-2008, 11:37 AM   #6 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Originally Posted by TTM77 View Post
O really?
At first, I got confused with the positive and negative, I installed it the wrong way... And it almost blew up my engine bay.
Old 08-15-2008, 12:41 PM   #7 (permalink)
"Circle of trust"
View catric69's Photo Gallery
I've had good luck with Sears batteries.
catric69 is offline   Reply With Quote
Old 08-15-2008, 02:11 PM   #8 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
I have Optima Red Tops in both of my vehicles and have had great success with them.
2006 Camry LE Special Edition
Old 08-15-2008, 04:01 PM   #9 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $462074
View BlackCamSe's Photo Gallery
go with Toyota OE batteries. At my dealer a few months ago i overheard a technician talking to a customer telling her that the battery that came with her 13 year old corolla was still in there and still ruining strong.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 08-15-2008, 04:55 PM   #10 (permalink)
View V6 LVR's Photo Gallery
I would go for the Optima Red/Yellow top battery when its time to replace my stock battery. Heat exposure is often the main killer of batteries, followed by vibration and maybe low fluid levels? I have been told by reputable techs that in Florida the life of batteries is 3 years max because of the temps year round.
V6 LVR is offline   Reply With Quote
Old 08-15-2008, 05:33 PM   #11 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
You can spend a fortune on a very nice battery and have it fail in short order or buy the cheapest piece of crap and have it work for years. I had an OEM battery fail in 3 months. My wife's Rav4 had her's fail just 14 months after she bought the car. Best I've seen was an OEM on a Ford that lasted 8 years. Just get a battery at WalMart, Pep Boys, or similar, clean the terminals, grease them a little when finished to slow oxidation, and let it run.
gdanaher is offline   Reply With Quote
Old 08-15-2008, 05:48 PM   #12 (permalink)
"Circle of trust"
I will add, it comes down to personal preference and what you are trying to achieve. Example: if you are installing a competition sound system, go for the yellow/red top.
Old 08-15-2008, 09:10 PM   #13 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Costco battery for $50...
2007 Camry 2.4L 5M
Old 08-15-2008, 09:34 PM   #14 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
+1
Old 08-15-2008, 11:23 PM   #15 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
O really?
MY MY MY...
This is a GREAT way to fry your alternator - or worse. You should never disconnect a cable with the engine running. Also batteries do not constantly overcharge. The alternator contains a regulator that keeps output within a specified range. The misinformation is really flying high on the site tonight.
