hes talking about the washer pump...to my knowlege the washer pump is inside the washer fluid resivior tank....to tell if its working properly or not, have someone sit in your drivers seat with the car running and pull the stalk for the windshield washers, and stand by the pass side bumper and listen for the humming noise of the pump going...if you dont hear it, the pump is bad...if you do, you have clogged washer fluid lines or nozzles, or theres a disconnect in the lines...my car had a similar issue, and the lines had just become disconnected.
The "Executive Sedan"
