2002 Camry LE Fog Light Wiring? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-18-2008, 04:40 AM   #1 (permalink)
Bmeclick's Avatar
View Bmeclick's Photo Gallery
USA 2002 Camry LE Fog Light Wiring?
I have a 2002 Camry Le 4 cyl and i purchased OEM fog lights for my car. my bumper has the pop out slots for the fog lights and also has a wiring harness already built in. i cant find for the life of me where the wiring harness goes so i can put a switch on it and run it next to the inside fuse panel too put a switch in one of my premade popouts. can someone please help and tell me where those harness run too
Bmeclick is offline   Reply With Quote
Old 08-18-2008, 03:25 PM   #2 (permalink)
Gameroom cash: $283730
View LE05's Photo Gallery
if you car is prewired and you are using the oem harness, you cannot use an aftermarket switch. you will have to buy the headlight stalk with the fog light switch on it to make it work. you may also need a fuse or relay or both to complete the circuit.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 08-19-2008, 01:44 AM   #3 (permalink)
View sundarpn's Photo Gallery
FYI BMEclick, it is cheaper & cleaner to by the aftermarket harness rather than but the headlight stalk with the fog light switch & the OEM relay etc. (I have an 2002 XLE and it has the oem harness, but it is useless)
I got the fog light kit from ebay and that has an aftermarket wire harness with relay & switch.
Now, I need to find the parking light wire to be able to tap into. This is so that, the fog light will turn on only when I have my parking lights on. (despite the fog light switch)
Can someone help me with which wire to tap into?
sundarpn is offline   Reply With Quote
Old 01-01-2009, 10:06 PM   #4 (permalink)
View SolidMac's Photo Gallery
Is the wiring for your 2002 Camry Le 4 cyl the same as a 2009 camrys wiring? if so, we seek the same answer. i cant find the correct wire to tap into.
SolidMac is offline   Reply With Quote
Old 01-02-2009, 06:48 PM   #5 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
look at my website and see how i did it.
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
