2007 Camry LE I4 auto engine braking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-18-2008, 07:57 PM   #1 (permalink)
View lb2007cle's Photo Gallery
I have read some threads about Camry engine braking but would like some opinions about what occurs with my car (2007 Camry LE I4 automatic). When the gas pedal is released the car slows down as if slight braking is being applied, until a downshift occurs when the car just coasts smoothly. This was observed in 3rd, 4th and 5th. This condition occurs most, but not all, of the time.
I measured the slowdown as follows - slowing down from 40 to 32 MPH took 7 seconds when the "engine braking" occurred and 30 seconds when it did not occur. This timing difference appears pretty dramatic to me. Again please note that after the car downshifts it coasts quite smoothly and does not appear to be slowing down much at all.
lb2007cle is offline   Reply With Quote
Old 08-18-2008, 08:30 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
When you downshift, whether you do it or the car does it automatically, the rate of acceleration will increase because there is more resistance compared to a higher gear.
The difference you witnessed in acceleration times from 40 to 32 is due to mechanical advantage through gearing.
2007 Camry 2.4L 5M
Old 08-18-2008, 08:37 PM   #3 (permalink)
Joined the dark side. :D
Gameroom cash: $654791
View workerant's Photo Gallery
I still prefer it's more smoother..instead of slow slow and than drag and pull back and than let go.... all without touching the break.
workerant is online now   Reply With Quote
Old 08-18-2008, 08:52 PM   #4 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Another over-analyzer is the OP and the previous post is more TTM77 gibberish.
Old 08-18-2008, 11:35 PM   #5 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Gameroom cash: $819821
iTrader Score: 16 reviews
View GT-R's Photo Gallery
Here we go again............
GT-R is offline   Reply With Quote
Old 08-19-2008, 12:19 AM   #6 (permalink)
View danorthface's Photo Gallery
i think most older cars don't shift gears while you coast so it feels smoother. The problem is if you accelerate while coasting then you're in the wrong gear and the car will jerk.
danorthface is offline   Reply With Quote
Old 08-19-2008, 07:03 PM   #7 (permalink)
EvoFire's Avatar
View EvoFire's Photo Gallery
Its because you touched the brakes and the car goes into engine braking mode. Maybe instead make sure you don't touch the brakes?
This has been beaten quite a few times... though I won't say to the death yet.
EvoFire is offline   Reply With Quote
Old 08-19-2008, 09:26 PM   #8 (permalink)
you don't need to touch the brakes for the car to shift gears while coasting..
Old 08-20-2008, 06:25 AM   #9 (permalink)
EvoFire's Avatar
From my understanding, it doesn't shift unless you touch the brakes or it gets to a low enough speed. Perhaps my information is wrong as I haven't driven a Camry. That is certainly the case on the new RAV4's and Yaris.
Old 08-20-2008, 10:04 AM   #10 (permalink)
nope, i have a gen6. When coasting to a stop without touching brakes the car will shift gears to match a speed/gear ratio. It won't feel like a smooth coast.
