help speaker wiring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-21-2008, 11:18 AM   #1 (permalink)
View jcurtin06's Photo Gallery
help speaker wiring
ok i need to splice into the rear speaker wires along the kickpanel but dont know which wire is which. there seems to be 2 of everywire so im lost on what to do.
what im trying to do is install 2 speakers.
how its going is new speakers into amp
amp into factory rear wires
so which color wires are the rear + - speakers? on both sides.
i really dont want to take the head unit off or anything else major thats why im trying to go threw the wires in the kickpanel. on my other car it was alot simpler.
jcurtin06 is offline   Reply With Quote
Old 08-21-2008, 01:17 PM   #2 (permalink)
squeakers's Avatar
View squeakers's Photo Gallery
there are two speakers in the rear deck, a 6x9 and a 1" tweeter. Which speakers do you need the wiring colors for?
squeakers is offline   Reply With Quote
Old 08-21-2008, 02:54 PM   #3 (permalink)
i need both rears.
well found out that i cant use the amp i have b/c you cant run 2 amps to do the same thing since the camry has an internal amp.
is this true or can i still do the idea i had by using the factory wires for the rear speakers to the amp im going to run.
and where is the factory amp located. i looked at the manual and it says its under the passenger seat but dont see nothing there but i read something else somewhere else i read the it was under the glove box
Old 08-21-2008, 03:05 PM   #4 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Unbelievable...................
Old 08-21-2008, 03:09 PM   #5 (permalink)
squeakers's Avatar
what year is it, it should be under the pass seat with a black cover over it. I have the factory amp in my car and i am running 3 seperate amps, i just bypassed the factory amp.
here are your colors
FRONT
dash by window
L+ pink
L- violet
R+ lt green
R- blue
DOORS
L+ pink
L- violet
R+ lt green
R- blue
REAR DECK WOOFER
L+ green/white
L- brown
R+ blue
R- yellow
REAR DECK TWEETER
L+ black
L- yellow
R+ red
R- white
keeping in mind you see the same wire colors for different speakers, you need to know which wiring harness each speaker comes from to decifer this. See the electrical wiring diagram for the repair manual pages 354 355
Old 08-21-2008, 03:13 PM   #6 (permalink)
squeakers's Avatar
what you will need to do is buy a line output convertor and convert the factory speaker wire into RCAs. If you buy the correct line output convertor it will be able to handle the factory wattage as an imput and you will have no problems. I recommend Audio Contol LC6i for this.
Old 08-22-2008, 11:58 AM   #7 (permalink)
thanks for the help i ended up not using the amp. just hooked up the speakers to the rear speakers. sounds alittle better. more highs and more bass. friend went into my car and was asked me what kinda subs i was running and i said thats all speakers.
now im going to use the amp for a 10" sub im going to buy.
now why do idiots like njerald make a reply saying unbelievable for.... if you have nothing to add then dont post. sorry if not everyone knows everything like you jerk.
Old 08-22-2008, 01:40 PM   #8 (permalink)
View sundarpn's Photo Gallery
can you tell what speakers did u got? Did it fit right in? (btw did ur camry have the JBL audio?)
sundarpn is offline   Reply With Quote
Old 08-22-2008, 01:50 PM   #9 (permalink)
Joined the dark side. :D
Gameroom cash: $654791
View workerant's Photo Gallery
Not sure it's a good idea to have 2 speakers on the same line. I mean speaker have impedance (like resister) and when you put them in parallel, I think impedance add while resistance divide. Anyway.. mathematically the # will be wrong. But seem like it doesn't cause any problem.
"unbelievable" is his trade mark. Just ignore it. LOL
workerant is online now   Reply With Quote
Old 08-22-2008, 03:01 PM   #10 (permalink)
well as far as the question does the speaker fit in right well i made the made to fit the speakers so yes they fit right in.
i have 6 speakers i think cus if i had 8 then i dont know where the other 2 are. so i guess i dont have jbl.
there 6x8 lightning audio 225w. i got them free so thats why i used them.
i also got a lightning 750w for 40 bucks new (originally cost 80, had a hook up @ walmart) which i bought for no reason now but i will end up buying a 600w 10"sub believe its pioneer and have it in the trunk for added thump.
yeah my friend told me that about the 2 speakers on the same line and it might make the rears not performance like normal but im having no problems with it.
Old 08-22-2008, 03:18 PM   #11 (permalink)
Is there a JBL logo on the receiver?
If it add like I think than basically the volume gets a little lower.
Old 08-22-2008, 03:25 PM   #12 (permalink)
exactly what he said it would do but its louder in the back now and if anything i hear the rears over everything more.
Old 08-22-2008, 03:28 PM   #13 (permalink)
just looked at the head unit and there is no jbl symbol.
Old 08-22-2008, 04:54 PM   #14 (permalink)
squeakers's Avatar
the head unit is a panasonic not jbl, the amp ans speakers are jbl
Old 08-22-2008, 06:13 PM   #15 (permalink)
'07 XLE
Gen6
Baloney.
If he doesn't have JBL on his headunit (he says he doesn't), he has a Fujitsu headunit and no amp.
ANOTHER THREAD TO DELETE.........
