hey TN..
i searched this site for others having problems with the I4/MT transmission and the results were close to nobody on the site were dealing with problems...
so i figured i'd start my own thread here and describe the problem i'm facing with the transmission, it nearly destroys all the fun!
first off, car is an a 07 (GL trim - second lowest trim), with 27K miles on the clock... car is my second manual and it went quite a few shift mistakes like downshifting VERY late, what your reguler manual begginer would do...
so then, i started noticing all these problems... what started as a 1-2 grind ended up 3rd gear poping out to nuetrul and finally third bieng unusable only way for me to keep it engaged is to keep a little throttle and my hand kept on the shifter to keep it in gear!
reverse is also grinding...
i can't make my 1st engage smoothley without reducing my speed to like 10 mph, second is the same only i have to reduce my speed to like 20 mph(1200 rpm in second), overall car is a LOUSY drive now...
i would like to know if it's just a synchros problem and if i can simply fix it by replacing the synchros or is it more involved then that like teeth damage...
gurus help me plz!
