Ground pint - dirver side interior. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2008, 07:08 PM   #1 (permalink)
View sundarpn's Photo Gallery
200 Camry XLE.
Got a fog light kit of ebay. I have to fix the square fog light switch on the driver side square pop out hole provided just beside the fuse box.
I need a grounding point here. Can't seem to find a good one. I looked!
Also need to tap into the lowbeam for the green wire so that the fog are on only when the lowbeams are on. I only see the tail light fuse here and seems to be a pain in the butt to tap into a fuse!
sundarpn is offline   Reply With Quote
Old 08-23-2008, 07:42 PM   #2 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
If there are no obvious screws in the body near your work area, make one. Find some metal up there that supports the dash or the side panel near the parking brake and drill a hole and follow it with a self tapping screw. Just don't drill through the outer body, electrical wiring, or hydraulic lines, and all is good.
gdanaher is offline   Reply With Quote
Old 08-23-2008, 07:47 PM   #3 (permalink)
View jcurtin06's Photo Gallery
you can ground it under the driver seat. just drill and self tapping screw
jcurtin06 is offline   Reply With Quote
Old 08-24-2008, 03:12 PM   #4 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
I've never heard of a 200 Camry XLE. What year is it?
2006 Camry LE Special Edition
Old 08-24-2008, 03:38 PM   #5 (permalink)
Gameroom cash: $283730
View LE05's Photo Gallery
there is a ground point in the driver's kick panel in the picture you posted... you didn't look hard enough. look for any bolt screwed into the "frame" just above everything in your picture. it may be hiding behind a big bundle of wires...
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 08-24-2008, 06:41 PM   #6 (permalink)
Maven
gdanaher's Avatar
In the time wasted discussing where to find or create a ground point a competent repairman could have drilled and tapped 50 screws to the interior body panels and fitted the danged car with all the ground points anyone could imagine. An expert repairman would have found 100.
Old 08-25-2008, 12:41 AM   #7 (permalink)
I found an existing ground point. Had to remove the panel under the steering col. 200 was a typo. 2002 camry. Thx.
FYI I also tapped into the 10 amp tail light fuse. Was pretty easy.
