Stopped really fast... now my stereo won't turn on? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-25-2008, 09:48 PM   #1 (permalink)
View grumbles's Photo Gallery
Gen6 Stopped really fast... now my stereo won't turn on?
I ran a remote turn-on wire from the back of my stereo and a power wire from my battery about six months ago to hook up a subwoofer/amp. Everything worked fine until tonight, where the person in front of me stopped suddenly, and so did I.
Well, as soon as I stopped, my subwoofer moved around in my trunk, and my radio went off. Not only did the stereo itself stop working, but the blue light around the stereo doesn't work either, no matter what, so it seems as if the entire unit isn't getting power.
Does anyone have any suggestions as to how I might go about fixing this, or what the problem might be? I honestly don't see how a remote turn-on wire or a power wire running from my battery to an amplifier could have anything to do with the stereo not working...
Thanks in advance.
2007 Camry SE V6
GS430 Wheels
245/45-R18 Yokohama Advan S4's
grumbles is offline   Reply With Quote
Old 08-25-2008, 09:53 PM   #2 (permalink)
Tap, Nap or Snap
dramaticlatino's Avatar
View dramaticlatino's Photo Gallery
Only thing I can think about is that the remote wire have been disconnected somewhere so the amp doesn't see that your car is on to power it up with the radio, but then again your radio not being lit up doesn't make sense, did you check your fuses? maybe two opposite wires contacted each other causing a short.
20" MetalFX MFX-2 w/ 245-35-20:SET Pedestal Spoiler:15% Tint:12" MTX Subs w/ MTX Amp:TRD Springs: DIY Yellow Fogs (thanks to Catric69) and LED conversion:6K Golden Eye H.I.D.
dramaticlatino is offline   Reply With Quote
Old 08-25-2008, 10:00 PM   #3 (permalink)
The only radio fuse I can access is the 15 amp under the hood, and yeah it seemed to be just fine.
Apparently there's another radio fuse behind the instrument panel, but I really have no way to access it without taking the *entire* dash apart, and taking the stereo itself out is a big enough pain as it is...
All of the wires in the harnesses behind the stereo itself are fine, none are pulled out or loose or anything, so this really isn't making much sense to me at all...
2007 Camry SE V6
GS430 Wheels
Old 08-26-2008, 06:34 AM   #4 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
The fuse in the dash should have a panel to remove to get to it. I havent done it yet in the gen 6 but you shouldnt have to take apart the dash to get a fuse.
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 08-26-2008, 09:48 AM   #5 (permalink)
View buno's Photo Gallery
Originally Posted by djkor View Post
The fuse box on the interior should be located behind your glove box. To access it, stick your head in the passenger side footwell looking up behind the glove box area. You will see a plastic panel which you can remove without any tools, and behind that will be the fuse box.
This is wrong information. The fuse box is located in the foot well in the drivers side. There is a panel that pulls off to expose the fuses and also tells what they go to. Unless you have really small fingers, you will need tweasers.
2007 Super White Camry SE V6
"Snow"
buno is offline   Reply With Quote
Old 08-26-2008, 10:17 AM   #6 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
He is an Aussie so it may be different there. Their pass side is our drivers side so it may in fact be the same area
MrSo0h0o is offline   Reply With Quote
Old 08-26-2008, 02:08 PM   #7 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
If the fuse is blown I would inspect the wiring to make sure there isn't any shorts. I'm guessing that you have a short somewhere in the wiring that occured during your panic stop. A panic stop should not affect the vehicle. I suspect it's in the add ons that you've done. Check everything VERY closely.
Is your battery secure? Could it have slid during your stop and disconnected the wire or caused a short?
2006 Camry LE Special Edition
