Service for iridium plugs? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-27-2008, 01:26 PM   #1 (permalink)
2004 Camry LE
somick's Avatar
Gameroom cash: $102015
View somick's Photo Gallery
I highly recommend doing this.
In the recent Rockauto news letter they mentioned that the spark plugs left in the engine for too long may create a problem in later days. Well they were right.
I have 45,000 miles on my 2004 LE. And as you all know we have iridium plugs installed there that do not need any attention before 100,000 miles or so.
When I tried to remove mine, I had to use quite some force. The threads were rusty at the bottom.
The job itself is not that hard. The biggest problem was to remove the engine cover: the rear of it is secured to the engine by rubber plugs that sit on the 6mm studs. I tried to pry them off but they did not budge. Fortunately I did not use lots of force. Appeared you need just to pull entire cover up.
Unplugged ignition coil connectors (ONE AT A TIME).
Installed anti seize compound and put everything back.
Sam
2004 Toyota Camry LE
1999 Honda Accord LX
1992 Subaru Loyale
2010 Subaru Forester
somick is offline   Reply With Quote
Old 08-27-2008, 01:50 PM   #2 (permalink)
View warpedrotor's Photo Gallery
Thanks for this, my 04 LE has 100,000 km and the plugs have not been changed. They are probably still good for another 100,000 km but will probably be stuck in the head at that point. Using your advice I will change them sooner than later.
warpedrotor is offline   Reply With Quote
Old 08-27-2008, 10:20 PM   #3 (permalink)
The Connoisseur
CharmCityES's Avatar
thanks for the advice...i have 65k on my camry and ill prob just change the suckers out next time i change my oil, but ill put some anti-seize on the threads of the new ones
The "Executive Sedan"
Old 08-28-2008, 12:09 PM   #4 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Really?
After seeing thousands of Toyotas at the dealership for maintenance I would have to disagree.
Change the plugs when they're due.
2006 Camry LE Special Edition
Old 08-28-2008, 12:29 PM   #5 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
Yea, Never experienced a problem on a Yota. I changed the plugs on my 1MZ V6 at 100k with no issues whatsoever.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 08-28-2008, 07:46 PM   #6 (permalink)
So the amount of time they're in isn't an issue?
Old 08-28-2008, 09:15 PM   #7 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
I just changed the original plugs on a 02 2.4 with over 100 thousand miles. No problems removing them from the engine. There was some erosion on the ground side, but the platinum chip looked ok.
2007 Camry 2.4L 5M
Old 08-29-2008, 08:10 PM   #8 (permalink)
Come to think of it, the only time I have had problems removing plugs was from an 82 Mazda 626 that had come back from Germany after being driven at around 100MPH (probably it's top speed) several times on the Autoban. The plugs had melted electrodes that damaged the threads when I removed them. That model required the use of colder plugs for extended high speed driving. The owner did not know this. I was still able to work them out and put fresh plugs in.
Old 08-31-2008, 07:25 PM   #9 (permalink)
TRD VVTi's Avatar
Gen5
Yes and no.
Replace spark plugs at the recommended intervals. See the factory maintenance guide for time or mileage.
Old 08-31-2008, 08:10 PM   #10 (permalink)
just a nobody
Have you or have the engine ever been washed? Water got trapped in the spark plug hole will cause the plug to rust if not a misfire.
N.E.O.
Old 08-31-2008, 08:32 PM   #11 (permalink)
LoudCamry's Avatar
Gameroom cash: $229327
View LoudCamry's Photo Gallery
what brand of spark plug is good?? or stay with oem, my car is not going to hit 100k soon but i am planning to do it early.
LoudCamry is offline   Reply With Quote
Old 08-31-2008, 09:24 PM   #12 (permalink)
just a nobody
OEM is the best bet, they would be in the right heat range and all the other stuff.
N.E.O.
Old 08-31-2008, 09:58 PM   #13 (permalink)
OEM is Denso or NGK. Either brand will work and tend to be the ones that work well consistently on Toyota vehicles from what I've seen on this board.
2007 Camry 2.4L 5M
Old 09-01-2008, 01:14 AM   #14 (permalink)
Originally Posted by TRD VVTi View Post
Yes and no.
I can only find a mention of mileage: 120,000 miles
I only put about 10,000-12,000 a year and I only have 60,000 now on an 04, so the spark plugs will be in there for about 9-10 years before I change them, opinion?
Old 09-01-2008, 01:18 AM   #15 (permalink)
If you want, you can take them out to inspect and put some anti-seize on there just to ensure they don't seize up. Unless you see something wrong with them, I say keep them until 120,000 miles.
2007 Camry 2.4L 5M
