ok sorry bout that in a bit of a rush. also real quick if you dont mind what would be my best bet on getting them off? some sort of flat metal and work it easily off?
Fishing line is the best, it's plastic and durable. Dental floss breaks so easily.
Oh, before you begin, spray the emblem and the surrounding area with water first, get it wet, so that you will not scratch/leave scuff marks on anything.
If you are careful take a hair dryer or heat gun on low and heat up the emblem a little to loosen the adhesive. Then take a good fishing line and work it under the emblem, works great! Just don't heat the paint up too much!
2008 Camry SE 4Cylinder/5Speed
2005 Tacoma DC/SB PreRunner V6
i wanna remove the "camry" and "le" off my car. its just held on by adhesive?
also if needed be can i put them right back on with adhesive?
last one how would i get the residue off the trunk from the adhesive if i took them off without scratching it?
do not use metal...
all the suggestions are good...
heat a little or do it in the middle of the afternoon.... take some fishing line or dental floss... get two sticks, screwdrivers etc.... and make yourself a little garrote... i.e. a string tied to two sticks so you can use them as handles.. and wont mess up your hands...
then get some rubbing compound... and go over where the emblems were...
as all things involving your paint and finish of the car... go slow take it easy, and it should turn out ok...
go easy on the goo-gone stuff when you use it. After you wiped off all the residue with goo-gone, it's best to wax that area to because you removed most of it with goo-gone.
use a little wax to clean out the spot after you're done.
2007 Magnetic Gray Camry LE V6:
Lit door sills, F/R cathode, trunk cathode, K&N SRI, IS250 chromes, LED tails/ bulb swaps, Katzkin leather
