'98 Camry squeal when first accelerate - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2008, 12:21 AM   #1 (permalink)
View Johno72's Photo Gallery
Haven't seen this exact problem in searches . .
Automatic transmission '98 Camry, 115,000 miles. When I start up, put it into gear (forward or reverse), and press the gas, I get a loud squeal/screech for a couple to a few seconds as long as I'm depressing the gas pedal (whether at a slow roll or accelerating), which then dissipates. It is a noise somewhat similar to a power steering squeal but it is not that.
BTW, I've also noticed in the last month or so that while accelerating to highway speeds the vehicle will rev a little higher than normal before shifting up. Not sure if that's related and suggests an overall transmission issue, but any advice is much appreciated!
-Johno
Johno72 is offline   Reply With Quote
Old 09-03-2008, 12:31 AM   #2 (permalink)
just a nobody
Have you check the belts? A slipping belt can sure may noise when under load. Both the V6 and 4L have two belts.
N.E.O.
Old 09-06-2008, 10:02 PM   #3 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $462074
View BlackCamSe's Photo Gallery
you posted in the wrong section. You have a gen 4, not a gen 5 or 6. The squeal is probably a lose/old accessory belt.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
