Because I kind of like your sincerity (OP), here is the 30K maintenance guide.
Credit goes to: http://smg.toyotapartsandservice.com/guides.php?v=3&y=2007&int_id=6&done=1
Thank you Toyotapartsandservices.com
2007 Camry
30,000 Miles - 36 Months
Replace engine oil and oil filter 1
Rotate tires
Replace cabin air filter
Replace engine air filter
Inspect the following:
Ball joints and dust covers
Brake lines and hoses
Brake linings/drums and brake pads/discs 3
Drive shaft boots
Engine coolant 4
Exhaust pipes and mountings
Front differential oil
Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
Fuel tank cap gasket
Radiator, condenser and/or intercooler
Steering gear box
Steering linkage and boots
Transmission fluid or oil
Note: Driving in heavy traffic, on dirt roads or in urban, dusty or desert areas may shorten the life of the cabin air filter. Replacement may be needed if you notice reduced airflow from the air conditioner and heater or if the windows fog easily when you use the "Fresh" mode. Consult your dealer if any of these conditions occur.
Additional Maintenance Items for Special Operating Conditions:
Driving While Towing
Replace differential oil (manual transmission models)
Replace manual transmission oil
Tighten nuts and bolts on chassis
Driving on Dirt Roads or Dusty Roads
Applicable Footnotes:
1) Reset the oil replacement reminder ("MAINT REQD") light after replacing engine oil.
3) Inspect thickness measurement and disc runout.
4) See Maintenance Definitions (Engine Coolant) for details.
