2003 Camry v6 trany fluid and oil change interval? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2008, 01:39 PM   #1 (permalink)
View crazygravy's Photo Gallery
Am the new owner of a used 2003 Camry with 56,000 miles. Have been going through the maintenance schedule book I received and see several references to inspecting the transmission fluid under the regular schedule. Also one under the special operating conditions schedule to change it at 60000. But I see nothing under the normal maintenance schedule to change it; only references to checking it. Is there a specific mileage to change it?
Also everyone says change the oil every 3000 miles but in my manual it references every 5000, or 7500 miles. What is best?
crazygravy is offline   Reply With Quote
Old 09-07-2008, 01:55 PM   #2 (permalink)
Asian N00b Modder
Gellenole's Avatar
View Gellenole's Photo Gallery
me personally I do over kill and change at 1500, but recommended is 3k if you are on pure synthetic 5k should be okay, but I'd stick with 3 over all if you're worried about money.
1995 Camry I4 @ 123k Miles - RIP 5-26-07
[Silverado Backed into it]
Originally Posted by catric69 View Post
It's cheaper if you get a new gf.
Gellenole is offline   Reply With Quote
Old 09-07-2008, 02:34 PM   #3 (permalink)
The Connoisseur
CharmCityES's Avatar
30k interval for the ATF per toyota specs for type ATF T-IV which is what your car uses
for oil, i say 3k-5k depending on how anal retentive you are
i use mobil 1 fully synthetic at 3k intervals myself.
The "Executive Sedan"
Old 09-07-2008, 05:00 PM   #4 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
Changing your ATF depends on how you feel about it (and naturally the condition of your fluid) but I changed mine at 25K miles and will change it again at 50K or less if need be. You need Toyota Type T-IV which is available at the parts department of your local Toyota dealer.
As far as oil changes, every 5K/5mo should be fine. It varies from person to person, some prefer to change it more/less often. I do mine every five months (I go by months, because I don't put more than 8K miles per year on my car) with synthetic.
'05 2AZ-FE @ 40K miles | '95 1MZ-FE @ 87K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
