Wondering if these will fit my Gen 6 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-08-2008, 06:03 PM   #1 (permalink)
View 08SeCamry's Photo Gallery
Gen6 Wondering if these will fit my Gen 6 Camry
wheel size-front-20x8.5 2.5" Lip rear-20x10 4.0" Lip
tire-falken front-245/35/20 rear-275/30/20 95% tread left
bolt pattern 5x114.3
wheel offset-front-25MM rear-40MM
08SeCamry is offline   Reply With Quote
Old 09-08-2008, 06:19 PM   #2 (permalink)
I Miss my I4VVTI
iTrader Score: 6 reviews
View gene112601's Photo Gallery
the front wheel will fit but not the rear 1....
gene112601 is offline   Reply With Quote
Old 09-08-2008, 06:20 PM   #3 (permalink)
Crash Test Dummy
View white07cam's Photo Gallery
eeeeh, that wont fit without modifications.
fender mods in the front and probably spacers with more fender mods in the rear.. it's doable and it would look sick if you went through with it
2007 Super White CE 5-spd. Stock 4 Lyfe, well I have new driver side doors and side pillar.. are those mods?
As of March 1, another $2200 body shop bill due to deer attack..
white07cam is offline   Reply With Quote
Old 09-08-2008, 06:44 PM   #4 (permalink)
Gen6 What About These Rims?
Product description
Lexion 203 made by Rays
+ CAST TWO-PIECE ALUMINUM WHEEL
+ COLOR -Diamond Black
INCLUDED
RAYS VALVE STEMS, CENTER CAP,
Tires- Toyo Proxes 4
Size- 235-35-19 & 265-30-19
19x9 Front & 19x10 Rear
Offset
+45
Bolt pattern
5x114.3
Old 09-08-2008, 06:50 PM   #5 (permalink)
Crash Test Dummy
those will need about as much work as the other ones, maybe a little less
but like i said before, go big or go home
Old 09-09-2008, 07:01 PM   #6 (permalink)
Under Reconstruction
Epsilon's Avatar
View Epsilon's Photo Gallery
I'll just answer your question here instead of through PM incase others wants to know. Since you're on stock suspension, the front will clear, but will stick out. As for the rear, it will definitely hit the struts unless you get spacers. I would recommend 15mm spacers for that nice aggressive fitment. Just incase you are wondering what they look like on a Camry:
Everything is the same down to the tire specs, except my offsets were switched, meaning I had +40 for the front and +25 for the rear.
Epsilon is offline   Reply With Quote
Old 09-09-2008, 09:44 PM   #7 (permalink)
instant noodle FTW
INDOMI's Avatar
View INDOMI's Photo Gallery
hey epsilon, do you have a rear shot of your car? i'd like to see how much the wheels stick out with 20x10 +25, cause with my 20x9.5 +30 the wheels stick out like 1.5 cm
INDOMI is offline   Reply With Quote
Old 09-09-2008, 09:49 PM   #8 (permalink)
Gen6
Indomi,
whats the offset you have on your rims?
Old 09-09-2008, 11:05 PM   #9 (permalink)
씨발
PRINCESS PEACH's Avatar
Gameroom cash: $209800
iTrader Score: 22 reviews
View PRINCESS PEACH's Photo Gallery
to the OP
the rear offset is too high. Your rim will hit your strut and will not clear.
Do you need car parts?
AdvanceSpeedShop
I Am Parting Out: click!
Questions about your own stupidity?: PM NJERALD
PRINCESS PEACH is offline   Reply With Quote
Old 09-09-2008, 11:06 PM   #10 (permalink)
Gen6
what if i put liek a 15mm spacer on it, would this help at all
Old 09-09-2008, 11:09 PM   #11 (permalink)
씨발
it'll clear the strut, but I'd worry about the fenders.
AdvanceSpeedShop
Old 09-09-2008, 11:11 PM   #12 (permalink)
Gen6
thanks for all the help guys, now i got alot of thinking to do
Old 09-10-2008, 01:05 AM   #13 (permalink)
Here and there...
Gameroom cash: $153229
View lammydi's Photo Gallery
If you decide to go with 15mm spacers then let me know because I have a pair of H&R spacers 15mm sitting in the garage waiting for a new owner.
Old 09-10-2008, 06:40 PM   #14 (permalink)
Title: 20 inch MRR GT1 Wheels Rims
Condition: Brand new
Diameter: 20 inch
Width: 8.5 front and 10.0 rear
Offsets: ET.35 front and ET.245 rear
Bolt pattern: 5x114.3
Finish: Silver w/ machined lip
Old 09-10-2008, 08:49 PM   #15 (permalink)
씨발
yes it will fit, but it'll depend on your tires and if you're dropping your car
AdvanceSpeedShop
