90K service - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-09-2008, 02:57 PM   #1 (permalink)
LoudCamry's Avatar
Gameroom cash: $229327
View LoudCamry's Photo Gallery
90K service
I am planning to do a early 90k serive. Are these the right part
Water pump , timing belt, power steering and alternator belt,
oil change and spark plug
new cabin filter
what other belt or part do i need
LoudCamry is offline   Reply With Quote
Old 09-09-2008, 03:30 PM   #2 (permalink)
씨발
PRINCESS PEACH's Avatar
Gameroom cash: $209800
iTrader Score: 22 reviews
View PRINCESS PEACH's Photo Gallery
http://smg.toyotapartsandservice.com...2005&int_id=18
Do you need car parts?
AdvanceSpeedShop
I Am Parting Out: click!
Questions about your own stupidity?: PM NJERALD
PRINCESS PEACH is offline   Reply With Quote
Old 09-10-2008, 07:41 PM   #3 (permalink)
View rdprx5's Photo Gallery
new cabin filter
What I did at around 90-95k was replaced:
(1) timing belt (2) water pump (3) front crank seal (4) camshaft seal (5) P/s belt (6)Ac belt (7) SEAL,TYPE T OIL (8) GASKET, OIL PUMP BOD
(9) Camshaft & timing - Pulley (10) Camshaft & timing - Idler pulley (the mechanic suggested the idler and pulley, though really dont have to do), and (11) changed the spark plugs. I bought all the parts at the dealer that cost me $310 and labor $260. (all of this would have cost me around $800-900 at the dealer)
And the normal: oil change, air/cabin filter, transmission drain/fill, and drained out the coolant.
rdprx5 is offline   Reply With Quote
Old 09-10-2008, 09:31 PM   #4 (permalink)
The Connoisseur
CharmCityES's Avatar
you have the V6 i assume?
you normally do timing belt, water pump, front crank seal, cam seal, a/c and p/s belts, spark plugs, oil change, coolant drain/fill, transmission flush or drain and fill, air filter, cabin filter and rotate tires at 90k for a V6 camry
for the 4cyl, its the same minus all the timing belt and waterpump stuff as it has a timing chain
The "Executive Sedan"
Old 09-11-2008, 12:30 AM   #5 (permalink)
LoudCamry's Avatar
alright, i already did all the flush just need timing belt, water pump, front crank seal, cam seal, a/c and p/s belt
AS for part should i stick with oem or is there other brand that is the same quality, i heard goodyear gatorback belt is more smoot and quieter then oem
Old 01-20-2009, 06:45 PM   #6 (permalink)
2007 Black XLE V6 Camry
View smilepak's Photo Gallery
new cabin filter
Don't forget Transmission Fluid. That's important!
smilepak is offline   Reply With Quote
Old 01-20-2009, 07:12 PM   #7 (permalink)
View joe07xle's Photo Gallery
I didn't think you needed to change seals are 90K I have a camry 2003 v-6 45k only on it. Is this just something that goes on the V-6 I did upper valve seals on my 1996 v-6
Joe
Camry 07 XLE-V6
Camry 03 SE-V6
joe07xle is offline   Reply With Quote
Old 01-20-2009, 08:18 PM   #8 (permalink)
The Connoisseur
Joe,
its not always a necessity to replace the seals at 90k, but we usually pair them with T belt and waterpump since its only a few extra bones for the seals and no extra labor since were already inside the timing cover for the waterpump and belts...most of the time theyre still ok, but well replace them so they wont start leaking after we do the 90k service
