Think I lost a head gasket - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-10-2008, 10:10 PM   #1 (permalink)
View dave0919's Photo Gallery
My 2002 4 cyl. w/147K started to push coolant out of the tank, replaced the cap with no improvement. When I fill the radiator and remove trapped air, the coolant is pushed out within a min. or so. ATemp is OK and I don't think it's ever been overheated. Looking for advise or more to look at. I would to do the HG job myself so any hints would help.
dave0919 is offline   Reply With Quote
Old 09-11-2008, 01:02 AM   #2 (permalink)
Rapid Roy's Avatar
View Rapid Roy's Photo Gallery
Are you saying the radiator empties out within one minute? The coolant is comming out of the overflow tube? Check your oil. If you blew the head gasket, there would probably be water in the oil. The oil will look like chocolate milk.
Rapid Roy is offline   Reply With Quote
Old 09-11-2008, 08:09 AM   #3 (permalink)
Asteroid's Avatar
View Asteroid's Photo Gallery
So it pushes the coolant out immediately from cold? Head seems likely. If it does it only when warm it may be a thermostat stuck closed.
04 ACV36R Camry Sportivo 4cyl manual
92 CE100 Corolla DX diesel (jdm import) *sold*
Asteroid is offline   Reply With Quote
Old 09-13-2008, 09:52 PM   #4 (permalink)
bigkidd's Avatar
View bigkidd's Photo Gallery
I work for AutoZone. I never see a head gasket blown. Thermostat or water pump.
bigkidd is offline   Reply With Quote
Old 09-13-2008, 10:20 PM   #5 (permalink)
Asteroid's Avatar
Errr, head gaskets are a super common problem on just about every car. Given the symptoms it seems extremely likely (coolant being forced out from combustion pressure).
Old 09-13-2008, 10:26 PM   #6 (permalink)
View 89molavi's Photo Gallery
If it is the head the coolant should be brownish/oily when pushed out. Good advice on checking the oil and also under the oil cap for foam build-up. At 147K anything is possible but might be something simple.
89molavi is offline   Reply With Quote
