door sills - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-15-2008, 01:05 AM   #1 (permalink)
09 Camry SE V6
shadeexone's Avatar
View shadeexone's Photo Gallery
Gen6 door sills
i just bought some door sills from ebay and the double sided tape it came with doesnt stick...i also put my own 3m double sided tape and it still wont stick on the car floor..what is the best way to stick the door sills????
shadeexone is offline   Reply With Quote
Old 09-15-2008, 01:39 AM   #2 (permalink)
View trdsupragt's Photo Gallery
I believe the ebay ones are supposed to stick over your stock sills.
trdsupragt is offline   Reply With Quote
Old 09-15-2008, 01:52 AM   #3 (permalink)
09 Camry SE V6
shadeexone's Avatar
yea i know...but my problem is the double sided tape and the extra double sided tape i used wont stick to the stock sills but it'll stick to the aftermarket sill
Old 09-15-2008, 01:55 AM   #4 (permalink)
씨발
PRINCESS PEACH's Avatar
Gameroom cash: $209800
iTrader Score: 22 reviews
View PRINCESS PEACH's Photo Gallery
did u use armor all or any product on ur sills to clean it?
if you did, you're going to have to use rubbing alcohol to clean it off. then the tape will stick.
Do you need car parts?
AdvanceSpeedShop
I Am Parting Out: click!
Questions about your own stupidity?: PM NJERALD
PRINCESS PEACH is offline   Reply With Quote
Old 09-15-2008, 02:02 AM   #5 (permalink)
09 Camry SE V6
shadeexone's Avatar
nope...havent used anything on it since i bought the car...i'll try the alcohol thing tomorrow
Old 09-15-2008, 02:03 AM   #6 (permalink)
씨발
definitely try it. I used armor all on my steering wheel console, and Gene couldn't mount the boost gauge lol. he had to use alcohol to wipe it down to make the tape stick.
AdvanceSpeedShop
Old 09-15-2008, 02:29 AM   #7 (permalink)
09 Camry SE V6
shadeexone's Avatar
and if that doesnt work what would u suggest???.....super glue..lol
Old 09-15-2008, 02:30 AM   #8 (permalink)
씨발
lol jb weld? rofl jk!
but yeah it should work. rubbing alcohol strips all the protectant from ur sills so it can stick nice and ez.
AdvanceSpeedShop
Old 09-15-2008, 02:50 AM   #9 (permalink)
Originally Posted by PrincessPeach View Post
stick nice and ez.
naughty naughty... papa spank!!
haha anyway.. it should have stuck on right away though. but like peach suggested, clean it up as much as you can. though you might want to try something to increase the adhesiveness of your sills as they might have gotten less adhesive from all the fitting.
Old 09-15-2008, 03:07 AM   #10 (permalink)
09 Camry SE V6
shadeexone's Avatar
will do
2009 Camry SE V6, 20 inch black w/ chrome lip, E&G Grille...
Old 09-15-2008, 09:36 AM   #11 (permalink)
jbergb5's Avatar
View jbergb5's Photo Gallery
shadeexone...Once you clean the surface where you want the sills installed...you need an Adhesion Promoter, These are comonly used on dash and trim kits. 3m makes one....I had to scoure the internet to find them. Seems to be available only in lrg quatities. I seem to remember I found them at a local Sherman Williams paint store. You also might try someplace local that has automotive paint supplies. Here's what you are looking for:
http://products3.3m.com/catalog/us/e...er/output_html
2008 SE - ASA AR1 wheels 18x8, General UHP 235/45/18, H&R Springs, 25% tint, Debadged, TRD Filter
Coming Soon:
Borla Exhaust
jbergb5 is offline   Reply With Quote
Old 09-15-2008, 04:32 PM   #12 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
clean it with rubbing alcohol as staed and let it dry then try remounting.
Also make sure its warm out when you are doing this, glue is more tacky in certain temps
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 09-15-2008, 04:45 PM   #13 (permalink)
View slick07LE's Photo Gallery
Nails?
slick07LE is offline   Reply With Quote
Old 09-15-2008, 05:30 PM   #14 (permalink)
victorkw's Avatar
View victorkw's Photo Gallery
Adhesion promoter.
http://cgi.ebay.com/ebaymotors/3M-Au...mZ190180066846
Just wipe down the surface first with rubbing alcohol to clean. Then use the adhesion promoter wipes on the surfaces that the tape will go on. I used this on one door sill that wouldn't stay down. I took it off, put some new 3m automotive mounting tape on and the moment the tape stuck to the surface that had adhesion promoter wiped on, it wouldn't come off. So make sure you line it up right! My door sill is slightly crooked now because i couldn't get it off. 2-4 packs should be good enough to do all four door sills.
victorkw is offline   Reply With Quote
Old 09-15-2008, 06:13 PM   #15 (permalink)
Go camry goooooo
DrewsCam's Avatar
if all else fails, velcro
