2AZ-FE tapping sound..Is this normal???? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-17-2008, 11:35 PM   #1 (permalink)
View egw23's Photo Gallery
I have a 03 Camry with 2AZ-FE. Took it to the dealership for a colant leak and they replaced the short block. Stud bolts stripped/streached. It was under warranty. About 1500 miles later I started hearing a tapping sound coming from the left side of the head. So I took it back and had the dealer and let them hear the sound. They agreed to replace the intake manifold and the spring tensioner for the belt. All under warranty. I drive the car another 500 miles and the tapping noise came back. Took it back in to the dealer they said to drive another 5000 miles and them bring it back to see if the sound gets worse. My question "Is this a normal sound???? Any help will be greatly appreciated.
egw23 is offline   Reply With Quote
Old 09-18-2008, 03:27 AM   #2 (permalink)
Asteroid's Avatar
View Asteroid's Photo Gallery
Well tapping can be a few different things. Does it come from the head or is it more external to the engine?
04 ACV36R Camry Sportivo 4cyl manual
92 CE100 Corolla DX diesel (jdm import) *sold*
Asteroid is offline   Reply With Quote
Old 09-18-2008, 01:23 PM   #3 (permalink)
The tapping sound comes from the head. Within the valve train. The sound is intermittent.
Old 09-18-2008, 06:40 PM   #4 (permalink)
bump.......
Old 09-23-2008, 12:17 PM   #5 (permalink)
bump..........
Old 09-23-2008, 12:28 PM   #6 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
why dont you record the sound and upload it.. its hard to diagnose a sound through words
MrSo0h0o is offline   Reply With Quote
Old 09-23-2008, 10:17 PM   #7 (permalink)
View twinklit's Photo Gallery
my '03 camry LE 4 cyc makes a clicking noise somewhere in the engine bay on the driver's side, faint but still audible.....was never able to identify the source even after serpentine belt was changed. I too had a coolant leak, but it was from the waterpump and it was replaced under warranty.
twinklit is offline   Reply With Quote
Old 09-24-2008, 09:38 PM   #8 (permalink)
self-proclaimed geenyus
jermyjerm's Avatar
View jermyjerm's Photo Gallery
Gen5
my '02 makes a very distinct ticking after I shifted into second the other day.Of course, I was going about 80 and looking for 4th!
jermyjerm is offline   Reply With Quote
Old 09-24-2008, 09:52 PM   #9 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $462074
View BlackCamSe's Photo Gallery
the 2AZ is a noisy engine in that way. It has a destinctive tap. If this is the nois ur hearing your fine
http://www.youtube.com/watch?v=VU8OyMq78tg
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 09-25-2008, 12:09 PM   #10 (permalink)
Rapid Roy's Avatar
View Rapid Roy's Photo Gallery
If your mechanic charged you for changing your timing belt, you were TAKEN! You engine has a timing chain and doesn't normaly need replacing.
Rapid Roy is offline   Reply With Quote
Old 09-25-2008, 01:52 PM   #11 (permalink)
The Connoisseur
CharmCityES's Avatar
he said serpantine belt....
water pump failure on the 2az is fairly common
the ticking noise is just the noise of the 2az valvetrain...they generally are a noisy engine
post a vid of the noise, as that would help us distinguish what the noise could be
The "Executive Sedan"
Old 09-25-2008, 02:03 PM   #12 (permalink)
Rapid Roy's Avatar
I guess I should read more carefully! I agree with you though, the 4 bangers make light tapping noises that many people mistake for engine problems.
Old 09-28-2008, 03:13 PM   #13 (permalink)
View Surfslinger's Photo Gallery
I had a very distinct tick at the time of delivery, and was told the same old B.S. it's just the way it sounds. figured it was perhaps a valve train issue as well, and the VSV valve will make a distinctive tick when it comes on line, but this was different and definitely near the WP, tensioner, etc.
Did a little research and found a TSB at the Jasper engine site,
http://www.jasperengines.com/pdf/Toy...ineNoiseTB.pdf
and told the dealer about it. I got the fix done and it is quieter in my experience, but is still there. Might be worth a try for you folks with effected years. Good luck!
Surfslinger is offline   Reply With Quote
