transmission - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-19-2008, 08:25 AM   #1 (permalink)
View camyred's Photo Gallery
transmission
When I first start up my 03 in the morning, I'll shift it into reverse and I can feel it kick in pretty hard. Then it does it again when I shift from reverse to drive. But after I drive it for a while, its really smooth. Is this normal? Or is my tranny taking a dump on me?
camyred is offline   Reply With Quote
Old 09-19-2008, 05:26 PM   #2 (permalink)
Gameroom cash: $283730
View LE05's Photo Gallery
it's normal. shifts will be rough until the car/transmission fluid warms up.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 09-20-2008, 02:35 PM   #3 (permalink)
View tvsjr's Photo Gallery
How long do you wait after startup before shifting? The engine will run faster (sometimes significantly faster) than warm idle, as a way of warming the motor and minimizing emissions. If you're one of the type that turns the key, slams it into gear, and goes, you're probably shifting before the motor winds down. Give it a few minutes and let the motor get to regular idle - the motor and transmission will thank you for it.
tvsjr is offline   Reply With Quote
Old 09-22-2008, 12:20 PM   #4 (permalink)
2004 Camry LE
somick's Avatar
Gameroom cash: $102015
View somick's Photo Gallery
Especially motor. It will build a lot of carbon in it due to lack of air...
I also feel a jolt on cold start ups. But it is enough to warm it up 20 to 30 seconds. Start driving after that and warm your engine while in motion.
Sam
2004 Toyota Camry LE
1999 Honda Accord LX
1992 Subaru Loyale
2010 Subaru Forester
somick is offline   Reply With Quote
Old 09-22-2008, 03:30 PM   #5 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
On cold starts the engine idles higher. Putting it into gear at high idle will cause that.
2006 Camry LE Special Edition
Old 09-22-2008, 08:43 PM   #6 (permalink)
View 89molavi's Photo Gallery
Check your mounts and tranny fluid level.
89molavi is offline   Reply With Quote
